2008 Tahoe 3-15's Tantric MD / Taramps - Car Audio Classifieds!
Old 07-10-2014, 09:49 PM
0/11 ssssss463
Default 2008 Tahoe 3-15's Tantric MD / Taramps
The blo thru truck is gone (sold). So I thought I'd try a Tahoe this time. All equipment was pulled from truck and have been working on the new install.
Pics so far
The ride
The twins 250a hairpins. MLA audio adjusted to "trick" PCM to full voltage
Enclosure 14.8 cuft Subs UP, port BACK
port 12" sonotube with homemade flares from mdf and router
Port painted and installed using 3" bolts/washers/T-nuts
Enclosure wrapped in vinyl with texture that matches the dashboard almost exactly. Had my sister sew a slip cover, spray glued 1/8" foam onto box, wrapped with cover and stapled the underside. Stitching was awesome.
The Power. HD4000 and a 1200x4. Fit nicely under the seat after taking plastic off bottom of seat to allow better cooling.
All I've got for now. Will start wiring tomorrow. Should have vids and more pics by Monday.
Old 07-10-2014, 09:57 PM
Astrophysicist's Avatar
Almost know nothing.
0/11 ssssss683
Love the wrap. And whip.
Old 07-10-2014, 10:04 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Sewing skills, are a rarity today.
Nice!
Old 10-03-2014, 07:51 PM
0/11 ssssss117
How did those taramps perform for you?
Old 10-03-2014, 08:51 PM
0/11 sssssss20
Like how the port looks
Old 10-04-2014, 09:19 AM
0/11 ssssss463
Amps still rocking. I have zero complaints. Currently wired at 2.6 nominal. Had it at 2 on 4-15's prior. Never shuts down. I run it at soft clip daily. They are, in my opinion, perfect for anyone wanting big power in a small footprint.
FYI selling the enclosure and subs to try a new project.
Old 10-04-2014, 10:14 AM
0/11 ssssss117
Thanks for the info! Been on the fence on hd8k.
You need to show me that alt trick I been worried about the charging problem. I had a 07 escalade and new to doing the myself.
Old 10-04-2014, 10:28 AM
0/11 ssssss463
Missing link audio module.
Old 10-04-2014, 10:29 AM
0/11 ssssss117
Thanks
8 tantric md 15's ltr450racer690 15" Subwoofers 17 07-06-2014 06:03 PM
WTT 2 Tantric HDD 15's d1 for 4 HD 15's d2 stssilverado Car Audio Trader (WTT) 2 09-27-2013 09:04 PM
Tantric 15's specs ?'s stssilverado Testing & Scientific Data Discussion 5 04-03-2013 10:40 PM
2008 Chevy Tahoe koopa Build Logs 238 11-07-2010 09:33 AM
