2007 Civic, P99RS, Seas, JL Audio and DSS - Car Audio Classifieds!
Old 07-11-2014, 09:14 PM
0/11 sssss1122
Feedback Score: 23 reviews
Default 2007 Civic, P99RS, Seas, JL Audio and DSS
I am helping a buddy revamp his install. He was using a JL Audio component set for the font stage and JL Audio 12w6 subs powered by JL Audio Slash amps. He bought my P99RS from me and is now running active I gave him a quick four hour tune while drinking some beers and we got the JL's sounding really good. Good enough to be winning competitions but he wanted more. He bought a set of Seas components and is hoping for a better sound. I recommended a different route but this is what he choose.
We have a lot to go yet on revamping his install. Here are a few pics of the Seas midrange install.
Old MDF baffles that I told him had to go.
I made new baffles out of cutting board. Unfortunately I didn't take pics of this step. I used my router with a circle jig to cut the baffles. The boards are 3/8" thick so we doubled up on them to get 3/4". I used hot glue to join the baffles and used ht glue again too seal them the to metal door and used four screws to fasten them. I applied gasket tape to seal the drivers to the baffles since the baffles flexed out of fat once being attached to the door.
We are no done yet with this install, I will have to take more pics once we meet up next. His setup will be in the winners circle for 2014
Old 07-11-2014, 09:20 PM
0/11 sssss1122
I am building his enclosure for two DSS 12" powered by two JL Audio 1200/1v3. We are going to need to assemble the enclosure in the trunk.*
He received one of the subs he is waiting on the second sub to be shipped.
Here is the enclosure shape, ignore the dimensions, they have changed.
I am using these "L" brackets to locate the panels. These will help a lot during the in-the-trunk assembly. Only issue with these is to make sure you make them square beforehand! Titebond III will hold it all together.
Preasssembly has started.
Old 07-11-2014, 09:23 PM
0/11 sssss1122
My bro said his second sub will arrive on Wednesday*:wacky:
Burning the midnight oil
Laying out the enclosure. When you build an enclosure in the trunk you have to preassemble every fastener and panel before hand. Building an enclosure is fairly simple but assembling it in the trunk is often much harder since you are maximizing every cubic inch.*
Old 07-11-2014, 09:27 PM
0/11 sssss1122
All edges are rounded. Speaker cut out and port painted to match the car.
One coat of ebony stain.
Old 07-11-2014, 09:29 PM
0/11 sssss1122
Old 07-11-2014, 09:32 PM
0/11 sssss1122
These JL Slash amps are huge!*
Cutting up metal
The amp rack is height adjustable to help with installation since EVERYTHING is tight.
The sub amps will be stacked. Mounted on the right side.
Going to be using the Knu distribution blocks.
Couple to do yet until this is done.
Old 07-11-2014, 09:34 PM
0/11 sssss1122
sssllllooooowwwwlllllllyyyyy *getting this done.
Red paint
Amp rack base is welded up
One of the mounting brackets before paint prep
Painting the base and supports a dull black
Tape off
Old 07-11-2014, 09:43 PM
myjaja's Avatar
0/11 sssss1060
Clean install. Nice to see builds on the same car as mine.
HU: Home stereo converted to dc
Speakers: Stock
Subs: 6 1/2 home sub
Amp: off the stereo
Wiring: extended power cord
neon lights: Christmas lights duct taped to frame
Old 07-11-2014, 09:54 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Those wood corner clamps look nice, how do you like them?
I only have the cheap kind.
Good show friend!
Old 07-11-2014, 11:45 PM
ridintwo6s's Avatar
0/11 sssss1791
Shoukd probabky invest in a kreg jig for those in trunk built enclosures, easilu my favortie tool in my shop and better hold then l brackets imo.
Looks boss though and I love thise subs, pretty damn beffy
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
2007 civic si coup problem Deegan2 General Car Audio Discussion & Questions 10 06-09-2014 10:55 PM
2007 Civic Trunk Class project twelvemeter Build Logs 25 03-09-2014 09:01 PM
2007 honda civic papito General Car Audio Discussion & Questions 2 12-13-2010 05:26 PM
New 2005 - 2007 Honda Civic alternator MECHMAN General Car Audio Discussion & Questions 0 08-16-2010 09:23 AM
