Ford Ranger 4x4 Build Log - Car Audio Classifieds!
Old 07-25-2014, 07:24 PM
danny1mmafan's Avatar
Old School Basshead
0/11 ssssss112
Default Ford Ranger Build American Bass
Ok guys this might not be a fast build log but it should be a good one. First thing I wanna say is im gonna post a couple youtube videos at the start of this log need a little help with mounting the second Machman alt and would like some feed back ifni am on the right track.
Ok so lets get started with what I have and were im starting
1. 2 Mechman HO alts 1st 240amp second is 270amp
2. 8 6 volt golf cart batts 1 batt = 2 group 31 batts so my batt bank will be eauivalent to 16 bats.
3. Double din cd/dvd player
4. Big 3 already done have all 0gauge wire for pos neg runs anl fuses ect
5. Going to run 4 or 6 ab xfl 15 NOT DECIDED ON BOX DESIGN YET (on there way soon)
6. I have 2 ab vfl 100.1 Need 2 more if I do 4 15 or 4 more if I do 6 15 not sure yet.
7 I have 8 selenium 6 and 4 selenium tweets getting ab vfl 350.4 for these
Ok so I think I listed everything I have and as you can see I have alot left tk get so this build wont be going super fast but I will stay onnit best I can. Tuesday I am rerouting the power steering pum resivor to make room for one of the alt so i will upload pics of that then. If yall have any comments suggestions on location of second alt I the ranger let me knkw I have never seen one with 2 alts.
Sorry I dont know how to.load the video so there in the youtube box thin.
Video one and yes I am a tard and cant operate my phone we filming. LOL
Here are a couple of youtube videos of the start of the build with alt location.
http://m.youtube.com/watch?v=hK0TUcFSy4c
Video 2
http://m.youtube.com/watch?v=kPb7kmOtg7U
Old 07-25-2014, 07:37 PM
socalxj's Avatar
0/11 sssss2371
Cool stepside 4 by ranger. I used to bow fish
Old 07-28-2014, 04:19 PM
Old School Basshead
0/11 ssssss112
Ok have a little update still waiting on the 2 mechman alts to get here but I got the power steering rese ior moved it is mounted on a plate and I tapped in to o screw coming off the motor. You will see alot of zip ties and no its not redneck technology they are just to hold the power steering pum in the middle so they dont rub on anything but it does look crazy. LOL what us bassheads will do
Old 07-30-2014, 02:17 PM
Old School Basshead
0/11 ssssss112
Ok a little update got I alt in and mailed out to Mechman other ones on its way when it gets here it will be mailed of to get new plugs put in them and get a double plug so I can run both alts together to power my batt bank. Regulators being changed in them and one plug on the 230 amp one since it was for a Ford Escape need it to fit my ranger. Also got 2 throttle cables out of an old a couple old expeditions and a lawn mower throttle mounted under my steering wheel so when I do demos I can adjust the rpms by hand rather then using my foot all the time. LOL I know im lazy but thought it was a cool idea. I will get some pics loaded in a little wile.
Old 07-30-2014, 03:51 PM
Old School Basshead
0/11 ssssss112
Here are the pics
Old 08-30-2014, 08:57 PM
Old School Basshead
0/11 ssssss112
Ok I got both Mechman alts in started the fabrication on the 240amp one. Here are a few picks of the fabrication of the bracket. Waiting on the plug for the 270amp one to come In to mount it.
Old 08-30-2014, 11:06 PM
That's pretty damn ingenious! Aside from moving the reservoir it's relatively simple and non-intrusive too.
Old 08-30-2014, 11:16 PM
0/11 sssss1642
I still have that 100.1 boxed up and ready to ship man. Build is looking good btw
Old 08-31-2014, 10:57 AM
Old School Basshead
0/11 ssssss112
Thanks man originally I was going to have the power steering pulley doubled up like a new YouTube video but after I realize the wobble would probably cause the bearings to wear out too quick in a power steering pump. I decided to come up with this fabrication took a little thinking but I think this is going to work for anybody that has an 04 Ranger this would work if they wanted to add a second alternator I hope it helps others. all I did was take a piece of cardboard made a template then cut it out of the piece of steel is the bolts are already made into the bracket off of the truck then got some threaded rod cut it fabricated the rest up simple as pie. once I have both alternators mounted and get the new belt I'll post more pics and a video of it this Thursday
Old 09-01-2014, 02:16 PM
Old School Basshead
0/11 ssssss112
LITTLE UPDATE Got the second alternator bracket completed and mounted got it painted idler pulley mounted all I need to do now is find a 12 volt power source when the keys turned on and get the proper belt for it and get the direct mount alt bolted on when the plug comes in tomorrow.
2010 Ford Ranger build. davidrforbus Build Logs 39 02-11-2015 10:34 AM
Zv4 18 In Cab Ford Ranger Build osage Build Logs 10 05-20-2014 08:03 PM
Ranger build log AQ28576 Build Logs 16 03-29-2013 09:11 PM
tylork92 Ford Ranger Build tylork92 Build Logs 24 08-02-2011 07:49 PM
Ford ranger semi wall build Bunkrd you4 Build Logs 43 11-15-2010 10:20 PM
