ford focus build. - Car Audio Classifieds!
Old 09-05-2014, 01:04 PM
0/11 sssssss81
Default ford focus build.
Hi new to here. And was thinking the best way to start out here would be to share my build. Its about 80% done as of now.
Pic of the car to start off.
Its a 01 ford focus se
2.0 split port 4 cylinder with about 50k on it.
Old 09-05-2014, 01:08 PM
0/11 sssssss81
First up was a Kenwood DD-x371
With the metra dash/harness kit. To be real dash kit don't look that good...
Old 09-05-2014, 01:14 PM
0/11 sssssss81
Next up was some doors.
Hifonics zrx 6.5" components
In each door. Had to cut some MDF plates to fit the 6.5s.
Old 09-05-2014, 01:45 PM
0/11 sssssss81
Well it is time for some A pillars.
I had 4- 1" alpine just collecting dust, and went out and got a pair of
Orion 4" super tweets. So each pillar will have 2-1" and a 4". Got some PVC
And cut it on 40 and hot glued them to the spot I wanted. Next I wrapped the
Pillar got the resin on, body filled it and out this stone finish on.( I don't like the stone finish now so it will get new paint or warped.
Old 09-05-2014, 01:56 PM
0/11 sssssss81
Big 3 in 1/0 sky high(power) and 1/0 stinger hpm (ground)
Old 09-05-2014, 02:19 PM
0/11 sssssss81
I had tsome soundqubed HDC3 12s
Old 09-05-2014, 02:21 PM
0/11 sssssss81
I got ^
Old 09-05-2014, 02:25 PM
0/11 sssssss81
Box time!
5.23 cuft net after sub's/bracing.
35hz
2-6" round ports
Old 09-05-2014, 02:32 PM
0/11 sssssss81
Box ^ in the back of my 13' sportage to try it out. But had to get it in
The focus. And then was time to seal in off. Kinda sucked due to the way I wanted to do the seal off I had to cover the paint. I used duck tape to make the shape I wanted. The resin over the top of it to make it hard and good stuff foam in back of it to make sure it was 100% sealed off.
Old 09-05-2014, 02:37 PM
0/11 sssssss81
Was not cool with the ports so I painted them with plasti dip. Got some digital designs deadener to cover the rear deck.
2000 Ford Focus xnewbx Build Logs 30 01-22-2014 09:11 AM
Alternator for Ford Focus? crice8 Alternator Price Quote Section 6 04-16-2013 09:44 PM
2000 ford focus littleharv93 Car Audio Packages 0 01-13-2013 01:52 PM
jl stealthbox for ford focus pschanz Craigslist Deals 2 09-15-2012 11:17 AM
My Ford Focus MKI PiastXD Member Rides & System Pictures 2 04-25-2011 04:13 PM
