GiGLZ 18" BEAST Rebuild - Car Audio Classifieds!
Old 09-27-2014, 11:36 PM
GiGLZ's Avatar
0/11 ssssss514
Default GiGLZ 18" BEAST Rebuild
Well its been a while since I've posted a sub build. Figure I'd post this one as it will shell out some damage.
Thank you to Lead Conceptz for the honour of testing out some of their new leadwire!
Let's start with the old version of the 18", where I needed a pretty crazy bunch of lead wire to support the potential power being thrown at this sub.
Previous version was built on a 4" coiled motor (ss xxx). Soft parts consisted of a zv4 cone w/ 4" opening, d2 4" 4 layer flatwound coil, 3 x spaced spiders w/ Sextuple leads..
LOL! You heard right! Sextuple!
470 bl^2/re and an fs of 26.24hz.
Metered out 148.5db on 2 x BB2400s strapped to 1 ohm
And for sh*ts & GiGLZ, 149.8 on a HD8000 on a single coil
Some pics of the OLD build.
Some videos of it on 2 x BB2400s strapped.
GiGLZ Testing - Youube
In the name of testing and wanting a little higher fs, I tore everything up and started over.
Lol.
Kept it simple with this build.
Went with a lighter wide roll surround, 2 x spaced spiders w/ the 5x leadwire I am testing out. . Its Beautiful stuff!
NEW build:
Had an install booked so had to pause and will resume progress soon.
Team Western Insanity
Vancouver, Canada
Old 09-28-2014, 08:51 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
moved to build log section (no one can reply in the miscellaneous)
Old 09-28-2014, 01:18 PM
GiGLZ's Avatar
0/11 ssssss514
The Prototype leads are from Lead Conceptz's soon to be released 5x series line that is still in the testing phases. They look VERY promising!
Rated Clean Power- 3,400 to 4,000 watts rms per terminal (+ & -)
Pull Strength- 161lbs
Vancouver, Canada
Tags
lead conceptz, stoopid big pictures
GiGLZ custom 15" 145.0db GiGLZ Car Audio Videos 4 07-20-2012 01:22 AM
GiGLZ 04 Toyota Echo 2012 Build GiGLZ Miscellaneous Build Logs 4 07-08-2012 04:45 PM
Skip01's: 2012 "End OF TIMES" rebuild.... 4 12s and 8,000w Skip01 Build Logs 87 03-17-2012 05:22 PM
Old School Orion XTR 2250 "The Beast" For Sale!! Bmoorman05 2-Channel Amplifiers 5 12-08-2011 02:08 PM
