Leave Well Enough Alone. Or Not. - Car Audio Classifieds!
Old 01-22-2015, 01:28 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default Leave Well Enough Alone. Or Not.
in a nut shell, im working on/have a few things going on that I figured id post pics of/share. no specific order, no expected finish dates.... only plans and hopes.
as of now, the expected projects are-
-rebuild an N2 motor, likely back to stock only unless I think of something stupid to do to it.
-Likely rebuilding 2 N3 motors. haven't decided if they'll be redone into what they are now... or something crazy that I have in mind.
-project super two. two 2" coil neo motors made from scratch. first models will use LMS/LMT coils that incorporate the varied winding with for a faltter BL curve.
- a side project that's for someone else that's waiting to be started. more info to come...
ill add photos in the following posts of what ive done so far.
Old 01-22-2015, 02:03 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Let's go...
Sent From Oklahoma
Old 01-22-2015, 02:24 PM
massivespl's Avatar
0/11 sssss8409
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 01-22-2015, 02:31 PM
Authorized Vendor
0/11 ssss14115
ill start with the N2. it was purchased at a price too stupid to say no. so I bought it. once I got it, it was a lot more then shifted as originally described. after disassembling the motor completely, and rather easily I may say, im not surprised it shifted. THIS IS NOT BASHING SO MOVE ON IF YOUR LOOKING FOR A TURD TOSSING MATCH.
the motor
first thing first was to remove the top plate. bolted a 15" basket to the top plate and yanked it off.
the thickness of the glue on this surface leads me to believe there was a height variance between the two sides other wise it would have oozed out.
the paint doesn't stick to the metal, at all. i know in the past, a vast majority of fi motor and fi built motors have rust bleeding through them from bad paint. my sp4 did, fi q's, new zcons that went from the box right into a 4th, etc.
upon removing the top plate i noticed the pole moved side to side so it as well was soon to be removed. it had came unthreaded some how. later on the screw was locked tight so i assume the pole is glued, then a bolt ran in as far as possible but it didn't hold the pole its self.
started to remove the side pillars. a single tap of a piece of wood it came right off real easy.
then the other side
one side had a hole in the plate and the other didn't. i assume this was to indicate what sides of the plates went where but based on some measurement the plates are symmetrical so it shouldn't need a specific direction that i could see.
you can see here the bit they used to open the screw hole to allow for the head to be recessed is slightly dull
the screw, as mentioned, had thread locker on it so i used an old school trick of using a reverse bit to get the screw hot. then it came right out
the heat sink design is a little interesting in regards to how its integrated into the motor. its just kinda set in. the top plate then pinches it tight. im sure they used it as a template width wise for pillar spacing as well as that makes sense. the fins were bent in a few places but then fixed.
the reason for failure on this motor was a broken glue bond. and im not surprised. the nickel coating on most of the neos was bubbled from an interaction with the adhesive. since the nickel plating is literally what your gluing too and not the actual neo, that's the weak link. in this case its a very weak one.
the ridge/mountain looking line on the right is where the bubble begins
touch it and it peels off
so it is what it is. but, on too a rebuild it goes.
Old 01-22-2015, 03:07 PM
Authorized Vendor
0/11 ssss14115
next up, some close ups of the super two motors. now, its hard to tell how big the pieces are but trust me... there TINY
i haven't ordered the pole pieces/columns/neo yet either
here is the projected final result
the whole family
back plate
top plate
these parts may be a bit confusing without the fully assembled photo. they serve a few purposes. they are jigs to place the neos and columns, a structural support once everything's in place and the top piece (that will be on the top plate) acts as a heat sink to wick away heat although the plate is a bit thin to have a huge impact.
a little size comparison...this is a 3" coil
more to come of course.
Old 01-22-2015, 03:09 PM
Authorized Vendor
0/11 ssss14115
also, i did get permission to share the project that's for someone else. more details on that once the motor arrives. then im going to make someone cry lol
Old 01-22-2015, 03:45 PM
0/11 sssss1882
Subbed for the knowledge.
Also makes me leary of going fi.
Fi="fvxk it?"
Old 01-22-2015, 04:00 PM
209native's Avatar
0/11 sssss1975
yeah me too i really enjoy watching jeffs builds. It's no bs5 sub but it will do till he starts another 4ft sub build
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
Old 01-22-2015, 05:51 PM
cerwinvega_fan's Avatar
Loyal Member
0/11 sssss1788
In for this one!!!
Old 01-22-2015, 09:16 PM
Inferno333's Avatar
0/11 sssss3845
Feedback Score: 44 reviews
I'm watching too Jeff.
This reminds me. I have a thought/picture to share with you. PM incoming tonight.
just going to leave this here Miguels (Tool Maker) 11 07-16-2014 10:08 PM
Cant leave well enough alone grimreper912003 General Car Audio Discussion & Questions 2 04-19-2011 06:29 PM
I'll just leave this here Sonically_Sound Uncensored Off Topic 6 02-16-2011 11:10 PM
Just going to leave this here. surreal Enclosure Discussion & Design Construction Help 18 02-01-2011 08:20 PM
I'll just leave this right here. Derrick824 (Sundown Audio) 28 09-17-2010 11:41 PM
