Ridnclean's Yukon Denali Build - Car Audio Classifieds!
Old 02-01-2015, 12:17 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
Default Ridnclean's Yukon Denali Build
This is for korey.
Simple build, trying to keep it as stock as possible and just add some bass.
04 Yukon Denali w Captains chairs, navi, RSE, etc
24s
JVC KD-R520 bluetooth/USB
American Bass 1/0
SHOK Wiring
Concept CM810/ Shark 2500D
Crossfire VR502 (i think)
SI HT18
Horn enclosure
Setup will be removable cause i use the 3rd row often so i will set up the wiring on a quick disconnect system or find a way to mount the amp hidden away from everything.
92 Ranger Walkthrough
(Under Construction)
Old 02-01-2015, 12:25 PM
0/11 ssssss857
in for the updates, sounds like a clean build planned ahead. I am working on a setup in the family SUV as well with 3rd row that is used time to time. Will be interested to see how you are doing the quick disconnects.
The Following User Says Thank You to ModFreak For This Useful Post:
RidnClean (02-01-2015)
Old 02-01-2015, 12:30 PM
about time.
now order the sub and build the box.
http://stereointegrity.com/product/ht18-18-subwoofer/
and just a reminder, that is an 18" subwoofer to give you scale on the enclosure size.
Old 02-01-2015, 12:40 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Thanks ModFreak, i leave for Portland on thursday so im hoping to have the wiring all done and amps setup by then and throw in somethin small for the roadtrip but i should have the 18 ordered and box done in the next couple weeks.
Old 02-01-2015, 12:45 PM
0/11 ssssss857
Im going to run two 8s in the Merc, and my plans were to be able to hide the amp in the hide-a-way compartment. Just need to figure out a spot for the mids and highs amp and a rear battery. If it works the way i would like, i am hoping to just have to disconnect speaker wire and pull out box, everything else should be hidden.
Old 02-01-2015, 01:49 PM
The goal on that enclosure was to show ridn why I say his other boxes, including the ones I designed, sounded like crap tonally. I ran a similar style enclosure in my gxp with a 12" and it sounded awesome. As long as the subwoofer doesn't act weirdly it should be the best sounding sub he's had yet.
The Following User Says Thank You to korey_hofer For This Useful Post:
RidnClean (02-02-2015)
Old 02-04-2015, 02:47 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12531
Hey Ridn, any spot for the amps? Can I suggest under the rear seat? That's what I did in my Tahoe. It's away, tucked under and won't interfear with anything and seats are still useable/functionqable.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501
Old 02-04-2015, 11:41 AM
Tried to say that already, he has gay seats instead of a bench
Old 02-04-2015, 02:41 PM
Sencheezy's Avatar
0/11 ssssss483
nice!!
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
Old 02-04-2015, 06:42 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
U2-55's?
My first build-log!! 02 Yukon Denali Andrew Build Logs 15 05-03-2011 03:29 PM
2002 Yukon Denali Andrew General Car Audio Discussion & Questions 38 07-10-2010 01:39 PM
2001 Yukon Denali XL 6.0L Alt TrUnK WaNgIn' General Car Audio Discussion & Questions 3 04-05-2010 06:43 PM
Need Alternator Help Yukon Denali crown_vic_driver General Car Audio Discussion & Questions 6 08-12-2009 08:10 AM
2005 Yukon Denali XL Price Quote crown_vic_driver General Car Audio Discussion & Questions 0 08-11-2009 12:38 PM
