Crown Victoria 4th Order Build - Car Audio Classifieds!
Old 03-26-2015, 09:45 PM
crownvicon26's's Avatar
0/11 sssss1882
Default Crown Victoria 4th Order Build
Been working on other peoples builds and finally got a chance today to start my rebuild. Im doing a 4th order bandpass with two zv3 15's on a ct 4k @.5. Electrical is 4 g31's j's 275 amp alt 2 pos and 2 neg ofc 1/0. The box will be 3 cubes sealed with 1.5 lbs of polyfil per cube and 9 cubes ported. 130 sq in. of port @ 47hz. The subs will be firing at an angle up towards the port. So far I have all the panels cut and will be building the port tomorrow hopefully. The box will be assembled in the trunk. Not much progress but will post a couple of pics anyway.
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 03-26-2015, 09:58 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Shit yeah! Tuned in
01 Volkswagen Golf 2 door
Kenwood ddx470
The Following User Says Thank You to Todd Dupler For This Useful Post:
crownvicon26's (03-26-2015)
Old 03-27-2015, 10:19 AM
0/11 sssss1882
Have a couple of questions guys. When building an external slot port, how large should the exit be? Should it be the same as my port height 7.5''? The port dimensions are 20'' wide and 7.5'' tall.
My second question is when inverting subs do I wire them as I would normally and switch the pos and neg on the speaker terminals?
Taramps 8k
2 Zv.3 15's
Old 03-27-2015, 08:17 PM
0/11 sssss1882
A little more progress today. I got the port done.
Batteries wired up.
Back, bottom and port in but not together. Just test fitting.
Taramps 8k
2 Zv.3 15's
Old 03-30-2015, 10:50 AM
0/11 sssss1882
Ok. Things just got real. My trunk will not close. Decided to cut and drop the front of the trunk pan but need to cut a little more to get the front of the box to sit flat because I still need a couple more inches to close it. I am also going to have to notch the trunk lid but Im gonna make it work. Lol.
Taramps 8k
2 Zv.3 15's
Old 03-30-2015, 11:22 AM
0/11 sssss2148
Feedback Score: 26 reviews
Knew it was coming and tuned in!!! Looking great so far!
Old 03-30-2015, 12:37 PM
massivespl's Avatar
0/11 sssss8409
U cut the floor out ur trunk to make the box almost fit?
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 03-30-2015, 12:50 PM
0/11 ssssss245
Wow You could have cut the corner off and put a piece on the inside cut a 45 to seal it. The volume lost could have been made up with some polyfill stuffing. Good luck cant wait for vids.
Before you cut anymore metal try to beat it out with a hammer it will stretch. Mark where its hitting and just cut out that spot then fiberglass over where you notched it out.
Old 03-30-2015, 01:29 PM
0/11 sssss1882
Tried beating it first. That was a no go. Have some more cutting to do to the pan and some deck lid modding to do. Didnt want to mess with the box. Probably illogical but it is what it is. Got a buddy that welds so we will work it out. Havent had a chance to really work on it from working on other peoples stuff.
Taramps 8k
2 Zv.3 15's
Old 03-30-2015, 01:34 PM
Biggcaddi's Avatar
0/11 sssssss59
Yes sir... 4th order trunk build, love it!!
04 Crown Victoria basslove Member Rides & System Pictures 2 12-05-2014 06:14 PM
Worst platform for audio - Ford Crown Victoria - HELP! Hertz5400LincolnLS General Car Audio Discussion & Questions 27 11-02-2012 01:40 AM
24'' wheels crown victoria. crownvicon26's Miscellaneous Stuff For Sale 8 03-25-2010 02:54 PM
[SOLD] 1998 Crown Victoria Police Interceptor crownvicon26's Miscellaneous Stuff For Sale 6 03-12-2010 02:59 PM
Alt for 2003 crown victoria donkryder954 General Car Audio Discussion & Questions 1 11-21-2009 10:23 AM
