blfuller123's 2001 Jetta TDI build - Car Audio Classifieds!
Old 09-19-2009, 03:42 PM
blfuller123's Avatar
0/11 ssssss223
Default blfuller123's 2001 Jetta TDI build
Woops, meant to post here first instead of the uninterrupted forum.
I have had this car for a couple of years now and have had a couple of smaller boxes in it, but now I am going to go a little bigger. I dont plan on competing, but I would like to put a meter on it and see what it will do.
I got in on the pre-sale for the RD 3250 v2 so that is the amp that will be running my subs. I got Patricks RD Alpha 12s and that should work good.
The head unit I use is an Alpine CDA 105. I am happy with it because it is practical for me.
I also run an older clarion pre-amp. I have had it for years.
I replaced the front and rear speakers with some boston acoustic components about 2 years ago. They still sound great and I will keep them. They are powered with my factory monsoon amp (no pictures).
The last week or two, I have started working on the car again. I have recently finished up the big 3 and run a single 3/0 back to the trunk that will tie into the c&d batteries.
I just have the factory 120 amp alternator right now but will be upgrading it as well.
Today, I got the old box that was in the trunk torn out. The new box will be 4.65 cu ft net, tuned to 45hz with 50 sq inches of port. The subs and port will fire forward and will be sealed from the trunk. I am considering having the port fire through the rear deck.
I might have all week to work on the car before I travel out of town again. Here is where I am at now.
Here is the radio/pre-amp
Here is the wire I used for the big 3 and the run to the trunk
1/0 and 3/0
3/0
Here is the battery after the big 3 were done. I want to get some custom terminals fabbed up to replace these.
Here is the trunk today after tearing out the old box that was in it.
Ebay Reference: beefller12 feedback 500+ 100% Positive
Scammed by Demonik Audio Tim Roy (Boomin SPL Sound Xtreme)
Old 09-19-2009, 03:50 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
dude, did you by any chance have any problems with your interior and exterior lights flickering before you did the big three? Also, how hard was it to get that pre-amp in there? and how do you hook that up?
Old 09-19-2009, 03:51 PM
0/11 ssssss223
As of now, I think I am going to mount the speakers and port like this. This is just behind the back seat. The port will be facing forward between the subs.
Old 09-19-2009, 03:54 PM
0/11 ssssss223
None at all.
Old 09-19-2009, 03:55 PM
Ryan1126's Avatar
0/11 sssss9178
damn thats weird, i cant figure out why her lights flicker like crazy, and when the turn signal is on her headlights dim a bunch.
Old 09-19-2009, 03:57 PM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
I would guess bad ground.
this should be a good build
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 09-19-2009, 03:58 PM
Ryan1126's Avatar
0/11 sssss9178
a bad ground on the amp?
Old 09-19-2009, 03:59 PM
Ryan1126's Avatar
0/11 sssss9178
my apologies for asking these questions in your thread dude, only because i was hoping you had the same problem.
Old 09-19-2009, 04:27 PM
Veteran Member
0/11 sssss3613
YGPM soon
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 09-19-2009, 04:37 PM
0/11 ssssss223
x2 on the ground. I had a 2K amp running a BL 15 and the lights never dimmed at all.
blfuller123's 2001 Jetta TDI build blfuller123 Uninterrupted Build Logs 0 09-19-2009 01:41 PM
Girlfriends Jetta build Ryan1126 Build Logs 49 08-25-2009 03:13 PM
S10 Extreme 2001 Any Info? thedukey42 General Car Audio Discussion & Questions 4 07-14-2009 11:02 AM
18" havoc in a Jetta? lunari General Car Audio Discussion & Questions 10 07-11-2009 04:26 PM
2001 Cadillac DeVille Build Log Bigboiii Build Logs 11 05-25-2009 01:11 AM
