Koreys 2004 bonneville build. - Car Audio Classifieds!
Old 04-25-2015, 01:22 PM
Default Koreys 2004 bonneville build.
Been a long time since I've done an actual build.
The plan is to get back on team sundown run their amps and possibly their 6.5'' subwoofers.
I've started the fab work on the front stage so we will see how that goes.
The idea is to not build a sq system per say, but instead what I think the optimal stereo should be like. It will stage correctly play relatively flat and be able to actual do the 3d mind tricks an actual sq car can do. My idea is to use either HAT imagine 6.5" subwoofers or sundowns x6.5" running midbass duty in my doors off of a sax150.4 bridged, 400rms each door. Along with a sae 50.4 running fullrange duty to a pair of dayton reference 3's, for now. The 3's should be able to tuck into the A pillars of the car and not really be that noticeable. For the sub stage I want to run a scv2000 to either a soft set up Zv4 12" or a stereo integrity hst-12.
This build will take a little bit as I work a lot and want to take the time to do everything correctly. I still need to order the deadener for entire car and not exactly sure how I am going to tame the flex and air movement the sub stage is going to generate. I tend to play absolutely every kind of music in my car ranging from normal metal and hard rock styles to industrial and modified music dropping into the single digit freqs.
I test fit the imagine I had laying here in the door, honesty looks factory.
as for the subwoofers enclosure, it's actually very simple. I wont give out the specs because people will freak out and just say how it won't work or sound like garbage. It's just a regular old ported enclosure though.
here is a picture of the car.
I've since then painted the wheels and started converting parts to blue rather than red I'll grab pics after it stops raining.
Old 04-25-2015, 07:01 PM
andy75's Avatar
0/11 ssssss788
You're gonna have to spill the beans on that enclosure. Looks like a small air space tuned really low. Kinda hard to tell what is going on with all that is going on. Lol
Old 04-25-2015, 07:11 PM
Box is pretty big, 20" per foot tuned super low and less chamber than people run for 10's
Old 04-25-2015, 09:00 PM
0/11 sssss1085
Feedback Score: 23 reviews
What do you have planned to reinforce those door panels for use as a baffle?
Old 04-25-2015, 09:07 PM
fiberglass and sheet metal, they will be deadened and all that shit to. I'm worried the driver will rip it's self out of the panel otherwise.
Old 04-25-2015, 09:13 PM
0/11 sssss1882
Tuned in for results. This should get interesting.
Old 04-25-2015, 10:36 PM
0/11 sssss2148
Feedback Score: 26 reviews
I like where this is going Korey, this should be a very interesting build from you..
Box design is crazy, and with a port that long and enclosure that small, its got to be tuned in the pre teens, lol.....but good stuff, cant wait to see the final results.
Old 04-25-2015, 10:41 PM
I bought this car to do the system, I'm going to take my time and make sure everything is the way I want it.
Old 04-26-2015, 02:59 PM
Tinted my taillights, was going to do the headlights but they are hazed to hell to I'll grab new housings first.
I'll post pics when they dry and are back on car
Old 04-26-2015, 03:23 PM
So Low's Avatar
0/11 sssss1258
Love the enclosure. Nothing wrong with some extra cone control
2004 Z71 Tahoe Build AQTahoeZ71 Build Logs 91 01-02-2014 09:51 PM
wall build for a 98 bonneville hj2010 Enclosure Discussion & Design Construction Help 59 02-20-2013 10:27 AM
1998 pontiac bonneville build. hj2010 General Car Audio Discussion & Questions 0 10-10-2012 01:17 PM
1994 Pontiac Bonneville Build Marros7 Build Logs 7 05-24-2012 09:02 AM
2004 Audi TT convertible build! 1coolrt Build Logs 3 02-29-2012 10:48 PM
