Fiero build log - Car Audio Classifieds!
Old 06-08-2015, 02:03 AM
Lock up your daughters!
0/11 sssss1342
Default Fiero build log
Ok, hopefully i won't get as much hate here. This forum seams much nicer. If you live in or near the Springfield Illinois area, let me know!
I just wanted to try something different. Hopefully you guys enjoy reading this.
My car doesn't like all these builds..
Here was my last setup with my DD Z and Banda 7k. It was ugly, but loud as hell
Amps were between the seats.
Teardown:
Current gear:
Fi Btl N3's with DD composite cones & dust caps built by Tantric. Thanks Jim!
Relocated headunit to driver's side:
Five group 49 Exide AGM's floating
300 pounds of battery just chillin'
Batteries all hooked up
Got my new Ampere 125.4 in
M4a with lots of furrrrrr
Subs were mounted in infinite baffle. the baffle was two layers of .75 MDF solid, but not pretty. All surfaces were coated in Polyester resin:
View from the driver's side:
Special thanks to Jeff for the 3D printed Fi decal!!
Got some Crescendo tweets and a bunch of Sundown Neopro 8's from the yardsale
Hopefully getting started on door pods tomorrow
I've got 10 gallons of Polyester resin for fiberglass and a bunch of red dye for it
Took subs out and will be starting on a ported box. Not sure if I'm going to try and salvage the baffle. the box will be covered in the same kind of red shag fur I used around my m4a in the trunk.
View from the front trunk:
M4a and amp rack is out. Batteries are covered right now to prevent loose tools from grounding my + bus bar:
Subs and amp are all in my room currently
200 feet of SHCA 2/0 OFC. I will be moving my sub amp to the roof of my car (on the inside, haha) and will be doing 10 runs of + and -. It is comparable to welding wire 4/0.
Few lugs too:
Old 06-08-2015, 02:37 AM
0/11 ssssss403
Dude, this is nutty. I like it. I don't think I could ever violate the interior like that, then again, interiors are so easy to come by looking in the right spot for these cars.
The Following User Says Thank You to BassMechanic308 For This Useful Post:
adulbrich (06-08-2015)
Old 06-08-2015, 08:10 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
Never would have thought to cut out dash to put enclosure in. Was curious where you were gonna find space for system in there. My friend had a '88 gt. Room for nothing.
Anyway, are you gonna make your own glas dash? With enclosure built in of course.
My game is legit,
The Following User Says Thank You to BallzFast For This Useful Post:
Old 06-08-2015, 08:24 AM
MR_MT's Avatar
Active Member
0/11 ssssss741
I am a bit confused as to what all exactly is going on but... Looks different man. Good luck. I look forward to the finished product.
Nothing special
Old 06-08-2015, 08:45 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
This is awesome!
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 06-08-2015, 09:00 AM
It's a mid engine car. The trunk is in the front forward of the dash, and there's a tiny little trunk in the very back of the car behind the engine.
OP: that looks crazy! One of my best friends had a MINT '86 GT in high school and I always wanted to do a bandpass install in the front but never did.
Old 06-08-2015, 09:41 AM
0/11 sssss1342
My original dash is currently hanging on a hook in the garage. It wasn't in great shape anyways
Only place left to glass is above the gauges if i do decide to do that. I may just stretch the fur across that area, because my fuse block is behind them, and i may need to access that in the future.
Wall is in the front instead of behind where you sit. 7k (before rise) going to some custom N3's
Originally Posted by Todd Dupler View Post
This is awesome!
Thanks!
Yea, I saw some builds on Fiero forums where they did an 8" sub bandpassed with some pvc pipe into the cabin. I wanted a bit more, haha
Hopefully more progress today, and more amplifier power later on!
Old 06-08-2015, 03:41 PM
doug118's Avatar
0/11 sssss4674
Please sell me those subs!
Old 06-08-2015, 03:58 PM
0/11 sssss1342
The pair cost me $1,800, so I'm kind of partial to them. I'd need to at least break even if I was going to let them go.
Not sure anyone else wants to pay that much for them. If you do, they're yours, haha.
I'd like some new DDZ's
Old 06-08-2015, 04:02 PM
doug118's Avatar
0/11 sssss4674
I wish they were just motors because that's all I need. Those things are insanely hard to find
Tags
adulbrich, composite, digital designs, fi audio, fiero
build log for the gf mcmuffin Build Logs 7 10-27-2011 09:21 AM
This is my first build log! Bradleyj0808 Build Logs 53 03-31-2011 10:40 AM
((Sa-15 build log)) Justin Team NWSPL 11 02-15-2011 12:35 AM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
my new to be build log. what else do i need snoopysnooper Off Topic Chat 1 12-17-2009 09:37 PM
