B Pillar in a ranger with 2 Hdc4 18's - Car Audio Classifieds!
Old 07-07-2015, 08:30 PM
0/11 ssssss106
Default B Pillar in a ranger with 2 Hdc4 18's
Not really a true build log, but some random pics i took along the way.
It needs trim panels, carpet, finished and secured port. Planned to make more progress this weekend but my debit card # got stolen so everything is on hold.
fml
conduit to protect the front to back 3/0 welding cable, no chances taken here
battery/amp box to go in the bed
fed the old boxes to the sky
fixed some rust from the bedliner.
screw unions, should be more durable than rubber grommets
Old 07-07-2015, 08:35 PM
0/11 ssssss106
crimped all the grounds to replace previous 4awg big 3
sky high 8awg for the speaker wire
then these bad boys showed up
they are huge
fixed a f**ed up alt to body ground
YUMM
spray foamed all the nooks and crannies
deadener removed
start of the wood roof bracing
boom! strong as hell
Old 07-07-2015, 08:38 PM
0/11 ssssss106
plasti dipped the window
it's my first wall build so go easy on me
baffle test fit
thats it for now, its been playing for a couple days but i dont want to post any more pics until its carpeted
Old 07-07-2015, 09:15 PM
0/11 sssss2055
when getting that wood to stick to the roof... is it just stuck by expanding foam or? lol.. I've never done that but always wondered how the hell it's being held up there ( the smaller pieces, didn't see screw holes in them )
I prefer to not like sundown because I feel like it's ****ing garbage.
Old 07-07-2015, 09:31 PM
0/11 ssssss106
yep spray foam lol within about two hours my fatass 240lbs could hang from one of those small pieces
Old 07-08-2015, 09:15 PM
Silver03gt's Avatar
0/11 ssssss687
Damn, spray foam sticks like that? Did you use 3/4 for it and will your headliner still snap into place?
2017 Chevrolet Silverado LT 1500 - Mechman 320 amp alt, possibly 4 DC M3 8s center console, some 3k amp.
2005 Ford F150 - bagged on 24s. Maybe new sound vehicle. (SOLD)
Old 07-08-2015, 10:43 PM
0/11 ssssss106
Its double layered 3/4''. I wanted minimal flex. I am going to trim the factory headliner to fit around the border to cover up all the sheet metal and then cover everything in fur lol
And yea, that stuff sticks hard as hell lol I was told to go that route by several walled people, and told to use the regular red can foam
Old 07-09-2015, 04:59 AM
0/11 ssssss179
What kind of port did you use with the depth and the "step up" on the bottom, I'm trying to picture how the port worked. Looks good though.
Old 07-09-2015, 05:04 AM
0/11 ssssss106
It's a center port that goes in between the seats up to about an inch from the roof. The port itself is 3" external and goes about 9 inches into the box including baffle thickness
Old 07-09-2015, 07:40 AM
0/11 ssssss179
OK. I think I've got the idea. Usually I see walls that use the entire height for port. That being when the shell can be entirely flat/squareish. Nice work utilizing all the space.
Pillar pods joey2010 General Car Audio Discussion & Questions 10 02-18-2013 11:17 AM
Fiberglass A-pillar Silver-N-black Sound Deadening & Fabrication 38 01-18-2013 01:03 AM
wall behind the c pillar? JEXTEL General Car Audio Discussion & Questions 21 12-12-2010 03:40 PM
Tweeters in B pillar? MisterTedster General Car Audio Discussion & Questions 7 12-09-2009 09:34 PM
