F*** Im doing a 6th order blow through - Car Audio Classifieds!
Old 07-12-2015, 09:20 AM
0/11 ssssss133
Default F*** Im doing a 6th order blow through
Well this is going to be my first build log on here. Going to be a slower build. But here is what will be happening. I have a 97 Chevy 1500 single cab truck with a 8ft bed with a camper shell on it. this gives me a ton of room to do a bunch of bass activity's. Going to be building a 6th order 1:1 ratio box for 4 18s that will be powered on a DC 5k for now. So with a general idea of what is goin on lets get this thread started
Current Set up consist of a Sundown Audio Zv4 10'' in a 1.8 cube box tuned to 32hz using 2 4'' aeros on a DD Z1 clamping 3092 rms. this is a center console box as well. As for mids and highs i have 4 prv 6MB200-4, 2 5MR450, and 2 TW450ti bullet tweets on a DD c4a. Decently loud right now was ale to do a 148.2 door open meter on the dash legal at 29hz. Pleased with it right now but i need more BASS!! So now im going to a blowthrough. any way here are some pictures or the current build before the changes start.
now let the fun begin
Old 07-12-2015, 09:26 AM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Nice.
What is the shiny textured coating in your doors? Is it just the photo or did you paint them with something?
Old 07-12-2015, 09:37 AM
0/11 ssssss133
www.youtube.com/watch?v=ZCJlEIgG29c
a little hair trick with the Zv4 10''
Old 07-12-2015, 09:39 AM
0/11 ssssss133
Originally Posted by craiggus365 View Post
Nice.
that would be a bedliner called monstaliner. I think it turned out really good. its a roll on bedliner that gets it texture from the roller.
Old 07-12-2015, 09:32 PM
0/11 ssssss133
wel i have spent a good amount of time designing and coming up with measurements and specs. Here is what i have design wise for my 6th order
its going to be a 1:1 ratio 6th aiming for a good flat response so it can be a good daily set up.
Specs -
Rear Chamber - 20 cubes 176 sq in of port using a 15'' aero that is 15'' long with a 1'' radius round over all around, tuned to 30 hz
Front Chamber - 20 cubes 600 sq in of port tuned to 60hz and the port would be 3.25 long
this will be a rear window blowthrough so the shape of the port is going to be as large as the window in the camper shell. as for subs this has been designed for 4 DC XL 18s but i am going to use Sundown SA 18s as temp subs. i have a drawing in AutoCad and this is most likely how everything is going to stay layout wise.
Old 07-12-2015, 10:42 PM
0/11 ssssss133
I knew it!
6th order blow through Box request for Bubba906 Bubba906 Box Requests 2 08-10-2012 10:28 PM
s10 blow through 4th or 6th order help.... usampsman Enclosure Discussion & Design Construction Help 13 02-03-2011 04:20 PM
