SNB778's New Setup in the Escape - Car Audio Classifieds!
Old 10-13-2009, 07:37 PM
0/11 ssssss798
Default SNB778's New Setup in the Escape
Well, as some of you know I had the 2x custom 15's in there before, but I want to change the port cause it was kind of sloppy (VERY SLOPPY), so in the mean time I put in my 18" SSX.........!!!!!!!
and WOW, that thing is impressive, suspension is as loose as i've ever seen a sub suspension, and it gets louder than my 2x15's off of the same power in the box it came with (i believe it was 4.7cu. ft tuned to 32hz claimed)
I just built a new box for it (not really a "build log, sry")
4.3cu. ft, 2x 6" external custom built flared aero's made from plant pots (worked Focking perfect!! $5 each!!!)
Started as a plant pot I got from work
Cut the plant pots...and Bam.. a perfect $30 flare just like PSP
Very solid 6" tube.. and a perfect fit
Threw em in the box which was a nightmare to build cause I kept f-in up...the original plan was to have both the ports on the back side of the box right above one-another, but with the flares, it didnt fit, and I had a double baffle, and wanted to try and stay below the window line
Bought the sub with the screw holes stripped out (didnt know at the time of purchase) so I had to use 1/2" screws instead.. but so far so good. It def. got even louder, and seems to hit with more authority over-all... Tuned at 38-40hz... gettin some more flexin now.. I'd imagine its hittin 148-150 sealed/legal right now
my plan now for the box with the 2x 15's is... I cut of the front of the box, and i'm going to put in 1x 10.5" flared aero which gives it a little more port than the 3x 6" tubes I had in there.... more port+better efficiency will hopefully give me some more output
Getlikeme:remote start
REFS: (from CA.com)Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle, mlstrass , Mazzasec, SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic meade forum. Team_Psi reconed SSX, Timmy13091 sold Deka Battery,
Old 10-13-2009, 07:38 PM
jbizzle's Avatar
0/11 sssss4346
Feedback Score: 26 reviews
Quiet...
j/k can't wait to hear it.
'07 Chevy Trailblazer SS AWD (Garage Queen)
- Alpine 9887
- Eclipse SC8365 3-Way front stage
- Sundown SAX-125.2
'98 Jeep Grand Cherokee (Daily)
- Alpine 9887 (Active)
- Selenium 6" Mids, 4 Crescendo CTS-1 Tweeters
- Sundown SAX-100.4D
- 2 Sundown SA-12s
- Sundown SAZ-1500Dv2
Team Sundown Audio
Old 10-13-2009, 07:44 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
you are officially a Home & Garden expert.
92 Ranger Walkthrough
(Under Construction)
Old 10-13-2009, 09:03 PM
0/11 ssssss798
dude, those things are perfect.. if anyone is interested in em, lemme know... can cut them to your prefered length/ radius (I wouldnt go more than 7", or you won't have much flare left).. but I can also get 8-10" buckets as well for prolly like 7-10 bucks
bizzle... i got tomorrow off.. hit me up if you are free.
Old 10-13-2009, 09:05 PM
0/11 ssssss798
i do electrical and lighting to....
should have seen the lamp-shape I fiberglassed over for my 10.5" flared aero.... couldnt figure out a way to cut it straight though so it didnt work out to well unfortunately
Old 10-14-2009, 01:42 AM
0/11 ssssss798
bring it up
Old 10-14-2009, 12:22 PM
0/11 ssssss798
ttt
Old 10-14-2009, 12:36 PM
toad559's Avatar
0/11 sssss1508
use the 4gauge screw for the strip holes. i used some on mine works great. just predrill it first
Old 10-14-2009, 12:45 PM
dak446's Avatar
0/11 sssss5914
nice man
Old 10-14-2009, 01:00 PM
0/11 ssssss798
for the ports??
wouldnt work... the cutout was to big.. I had to load it up with caulk and epoxy to seal it.. but hey, it works...... looks like absolute crap, but it works
My HT setup. tater General Home Audio/Video 2 06-28-2009 06:03 AM
Yep... About time for the new setup... jbizzle General Car Audio Discussion & Questions 13 06-11-2009 09:22 AM
My First Setup cttan_84 Member Rides & System Pictures 13 05-20-2009 03:18 AM
Who's setup is this?!?! canyouhearmatt Car Audio Videos 5 02-28-2009 09:17 AM
New Setup! mazda6i07 General Car Audio Discussion & Questions 8 11-17-2008 11:09 AM
