Team FI 15s 4th order wall build - Car Audio Classifieds!
Old 08-31-2015, 06:43 AM
0/11 sssss4519
Default Team FI 15s 4th order wall build
Little build I did for a buddy. Two team FI 15s in a 4th order wall, going to be powered by a pair of Crescendo 5500s.
Lot's of Murder Mat
To find sealed resonance
resolve Vas/28.32 =
result of that +1
square root that result
Old 08-31-2015, 06:49 AM
0/11 sssss4519
resolve Vas/28.32 =
result of that +1
Old 08-31-2015, 07:56 AM
0/11 ssssss281
Very nice, what kind of paint did you use looks very smooth.
Old 08-31-2015, 09:35 AM
0/11 sssss4519
The black is rusto high gloss, the green is Valspar piss can, and the white is Sherwinn Williams high gloss. I use foam cabinet rollers and sand with 320 in between coats and 600-800 on the last coat.
resolve Vas/28.32 =
result of that +1
Old 08-31-2015, 09:40 AM
onebadmonte's Avatar
0/11 sssss1221
Nice work. Those are beast of subs. Mine laughed at the orion 3700 I had on it. I'm sure the crescendos will get them moving. How's it sound?
The Following User Says Thank You to onebadmonte For This Useful Post:
LyferXB9s (08-31-2015)
Old 08-31-2015, 10:09 AM
Thelonewolf's Avatar
CACO SLACKER
0/11 ssssss597
looks clean!
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
"Puny god" - The Hulk
Old 08-31-2015, 11:15 AM
Sencheezy's Avatar
0/11 ssssss483
man that looks good!
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
The Following User Says Thank You to Sencheezy For This Useful Post:
Old 08-31-2015, 12:00 PM
tboorn's Avatar
Fi Enthusiast
0/11 ssssss343
is it a c-pillar wall?
looks very nice!
Fidelity--Built To Last--Team Sound Asleep
I've never, not one time, seen a gain from 45's. People think of ports as a wind tunnel. They don't work that way. They resonate. They don't produce wind. If it was a wind tunnel, 45's would be more than justified. But it isn't.
Old 08-31-2015, 07:53 PM
0/11 sssss4519
Yea it's a c pillar
resolve Vas/28.32 =
result of that +1
Old 08-31-2015, 09:08 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Does that port shape have a geometric name? Square with cut off corners? Truncated Square/Diamond?
Team MN Loudest - Team Sundown 8 15 zv3, 4 NS-1s, 4th Order Build Masterofallbass Build Logs 1564 12-02-2013 12:42 AM
4 15s flat wall or 2 15s large ratio 4th? mads10bass General Car Audio Discussion & Questions 7 02-04-2013 01:13 AM
93 Chevy Lumina 4th order wall build xnewbx Build Logs 18 09-11-2012 06:50 PM
1995 Honda Civic coupe 4th order wall build Russla Build Logs 14 07-27-2012 05:18 PM
The Jeep : 4th Order No-Wall Build sundownz (Sundown Audio) 30 02-14-2011 04:44 PM
