Going for my first 60 in a Subaru Legacy - Car Audio Classifieds!
Old 10-07-2015, 10:15 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
Default Going for my first 60 in a Subaru Legacy
Project Subwoofaru. (name is still being decided on lol)
As far as I know this will be the first Legacy to hit a 60.
So the build:
4 Ampere 3.0 15s. TFE and XS18kSPL/caps in the future when the funds are available.
Literally got these today. Glad to swap out my Tantrics with these.
What this build has done:
157.28 at 45hz with 4 HDD 15s on 8k clipped to hell with my port breaking in the process.
What needs to be done:
-Steel bracing added to box to fix some flexing
-Inside of box glassed to stop any possible air leaks
-Box secured to B pillars with steel strapping
-Glassing around edge of box (wall) all the way around the vehicle for total cabin separation
-New port made from sewer pipe and mdf
-Vibraflex added to floor,ceiling and doors eventually
60 is the lowest I expect with all these changes
Current Build:
#60sHereIcome
Old 10-07-2015, 10:23 PM
SINTORMAN's Avatar
0/11 sssss4907
What I did today. Started tackling box bracing. Using 2" square box tubing 1/4" wall thickness.. Stuff is retarded beefy. Also 4 5" square 3/8" plates.
Here's what the box looks like without subs or a port:
Drilling out the plates:
Going at this a little differently than most people. Most guys will brace by bolting the steel to the box using bolts. Thus having to put bolts through the box. Unfortunately I don't have that luxury in some of the spots so I had to think outside of the box. Steel meet wood:
Wood will be bolted to the steel with 4 bolts and then 8 #10 decking screws go through both layers and wood is glued to box. Effective 20 square inches ish of glue bond area plus 8 screws.. Will not let go. Mounting a plate:
Kind of fuzzy sorry. Dem angles:
Trying to cut that tubing with a chop saw... Nope:
Had to switch to little cutoff wheels.. Go through one per cut lol. Test fitting the first two pieces. Success:
Can still do a decent weld despite the crappy welder and helmet I'm using lol:
To more supports to go. One attached to the bottom of the box and one attached to the top.
Current Build:
#60sHereIcome
Old 10-07-2015, 11:05 PM
doug118's Avatar
0/11 sssss4674
What size port do you run? Why not use metal flares?
Old 10-07-2015, 11:44 PM
SINTORMAN's Avatar
0/11 sssss4907
15". I considered a psycho port but I can't afford one right now. Like 220 for a static one. I got a huge roundover bit that will make good flares.
Current Build:
#60sHereIcome
Old 10-08-2015, 12:03 AM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Sounds like it should be pretty damn solid! What year is your legacy?
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 10-08-2015, 12:27 AM
SINTORMAN's Avatar
0/11 sssss4907
2005. Feel free to post up guys. Can't wait to try out these Ampere's. Being perfectly honest the motor is a little smaller than I was expecting but tsps still look promising for SPL. Especially lower power. Might finally have a lead on getting rid of my Tantrics.. Fingers crossed.
Current Build:
#60sHereIcome
The Following User Says Thank You to SINTORMAN For This Useful Post:
Goldfishrock1 (10-09-2015)
Old 10-08-2015, 01:20 AM
spl_robb's Avatar
0/11 ssssss571
looking good man!!!
waiting on more pics and vid when finished...
(2)10" Mids (2) HornsD290Py S (2)TW 700Ti all PRV
2 x 18" DSS SAVAGES/2 x SOUNDIGITAL 12K @1 ohm
4 BANKS OF SCAPS/ shca ofc cable wire 4 runs.
Old 10-08-2015, 06:19 AM
Red Light Ear Rapist
0/11 sssss1397
So the build:
lol i just got 4 ampere 3.0s to for my legacy too!!! havent had time yet to build the wall though, and was also running tantric hdds.
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 10-08-2015, 06:40 AM
redcon1's Avatar
Broke & Horny
0/11 ssssss526
What was the wait time on the subs?
Old 10-08-2015, 06:42 AM
0/11 sssss1397
had mine within 5 days of ordering
4 Crossfire v4 18s
2013 Subaru Legacy + subwoofer Thelonewolf General Car Audio Discussion & Questions 2 02-18-2015 09:32 AM
subaru legacy windshield flex SINTORMAN Car Audio Videos 3 11-19-2014 06:08 PM
2009 subaru legacy ltr450racer690 General Car Audio Discussion & Questions 1 12-15-2010 07:43 AM
bat for a 2009 subaru legacy?? ltr450racer690 General Car Audio Discussion & Questions 2 12-03-2010 10:30 AM
04 Subaru Legacy, Why can't I find any info? goodstuff General Car Audio Discussion & Questions 1 11-05-2009 01:08 AM
