SounDrive Tahoe Build Log - Car Audio Classifieds!
Old 10-28-2015, 04:55 PM
SantaClawZ's Avatar
CEO, SounDrive Audio
0/11 ssssss374
Default SounDrive Tahoe Build Log
Welcome to the build log for the SounDrive Tahoe which also happens to be my daily driver It's built for both competition and daily listening/demos.
I'll start off with a current equipment list that I will update as needed then post pictures starting from when I bought the Tahoe earlier this year until now.
04 Tahoe LS - 93,000 Miles
Subwoofers: 2 DD 99z Tight Gap (First DDZ model)
Sub Amp: Taramps HD10k 2 ohm
Head unit: Alpine 9887
Mids/Highs: 4 CDT HD 6.5" coax
Mids/Highs Amp: None yet
Alternators: 370a Mechman Elite + 130a stock alt on a Mechman dual bracket
Underhood Batteries: 1 NorthStar 34/78
Other Batteries/Electrical: 1 Northstar 8DK
Sound Deadener: Knu Kolossus 100 mil (front doors only)
Power Wire: Red/Black Electron Beam 2/0
RCAs: Custom SounDrive 17' 2ch to 4ch splitters (2ch currently not in use)
SounDrive XTerra
8 SounDrive SDA3 15s | 2 Taramps Bass 12k | 2 Taramps DSP1600 | XS D3400 | 200ah SounDrive Lithium | DC Power 320a | Mechman 170a
Old 10-28-2015, 04:59 PM
SantaClawZ's Avatar
0/11 ssssss374
Pictures right when I bought it in May:
The majority of the door speakers were blown out when I purchased it so I replaced them with some CDT HD series coax for a temporary fix.
Stock 6.5" location...
I bought an adapter so I wouldn't have to modify anything. Guess what, it didn't fit.
6.5" fit in the stock hole just fine so...
Self tappers won this battle.
SounDrive XTerra
Old 10-28-2015, 05:01 PM
SantaClawZ's Avatar
0/11 ssssss374
Next task was to deaden the front doors. They're huge.
Outer skin is completely covered. Inner skin isn't perfect but I plan on redoing it with a few large pieces of deadener for full coverage.
Snapped another pic at this point
SounDrive XTerra
Old 10-28-2015, 05:07 PM
SantaClawZ's Avatar
0/11 ssssss374
There was a show that weekend so I bought a box from a friend to throw in temporarily
Amps at this stage were 2 Taramp's DSP3k 1 ohm. They're pretty cool little amps. I had them set so that at 1% clipping, they cut back and would not clip any harder. Cool little feature of the DSP series.
Put it all in the back. 4 NSB group 31s. Fits like it was made for the Tahoe.
NSB 34/78 went in as well
Managed to start breaking interior pieces already
Kinda failed at the first show. The 1% clip limiter really held back my output, later found out I had an issue with the sub level control on my HU, and the box just blew for numbers since it was tuned at 29 with not enough port area. Ray at Sonus clamped the amps doing 600w each after rise though with the clip limiter and hellacious rise, so I guess it's not as terrible of a score as I make it out to be.
Metered a 144.9 sealed up which caused this interesting post from a competitor
SounDrive XTerra
Old 10-28-2015, 05:15 PM
SantaClawZ's Avatar
0/11 ssssss374
Next step was the alts. I am a mechman dealer so naturally I went with a 370a elite and their dual bracket - they only had 2 left and they're discontinued.
Time to take the sawzall to a new (to me) vehicle, because, why not. Had to cut off a tiny bit of the stock alt bracket so the second alt would clear.
Picture of the alts in
Now it was clearly time for a new box design. I wanted something loud. Not kinda loud, really loud. And with a little inspiration from Alan Hall's build and a lot of modifications I came up with this design... which I didn't stick with. I did stick with the baltic birch though. This stuff is great.
I ended up changing some things around and ended up with this. One port plugged for daily, both wide open for competing. And wow, it was amazing what a difference made. At this point I had sold one of the DSP3k and was running a single one at 2 ohm - so 1500w before rise. It was really close to as loud as the last enclosure was on 1/4 of the power. Strapped it in as it was time to go back to school for a week and work on it again the next weekend.
Did some fancy sub wiring here.
Hello there.
SounDrive XTerra
Old 10-28-2015, 05:23 PM
SantaClawZ's Avatar
0/11 ssssss374
Finally came up with a temporary fix for the awful wheels at this point. I need to redo 3 of the wheels as they're peeling off; I think it's because of all the concavity in the wheel.
What better way to get louder than by adding more power? The HD10k 2 ohm was finally ready to be ordered in the US and I got one of the first ones right before finals.. less than a week before actually
Replaced my fancy brass bolts with even more fancy, larger aluminum bolts and copper washers for more conductivity. Does it do anything? Probably not. Does it look cool? Yup. Couldn't find copper lugs with a hole large enough for the huge aluminum stud
Finally got the false floor in - also installed the NorthStar 8DK with toolmaker battery terminals. I also put some Toolmaker terminals up front on the 34/78
And what you've all been waiting for. We metered it after all of this.. so no deadening on most of the doors, hatch, or roof yet. No testing with box placement and no modifications to the box like rounding corners or resin yet.
155.7 outlaw. Not bad for a first trial in my opinion. Now, to get my headrest score up there since I compete in MECA.
SounDrive XTerra
Old 10-28-2015, 06:19 PM
tboorn's Avatar
Fi Enthusiast
0/11 ssssss343
freakin sweet score man! keep up the good work it looks awesome
Fidelity--Built To Last--Team Sound Asleep
I've never, not one time, seen a gain from 45's. People think of ports as a wind tunnel. They don't work that way. They resonate. They don't produce wind. If it was a wind tunnel, 45's would be more than justified. But it isn't.
The Following User Says Thank You to tboorn For This Useful Post:
SantaClawZ (10-28-2015)
Old 10-29-2015, 01:33 PM
SantaClawZ's Avatar
0/11 ssssss374
More power coming soon
SounDrive XTerra
Old 10-29-2015, 07:35 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
What's the peak and number with the plug?
Also... link to plumber's plug?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 10-29-2015, 07:44 PM
0/11 sssss1528
Wow! Nice turn around on the score man. Tuned in!
4-18 ethos tahoe build 2015 build Tahoe89 Direct Sound Solutions 48 01-21-2016 01:43 AM
96 Tahoe build log :D regizzle Build Logs 4 01-15-2012 10:10 PM
2007 Tahoe Build Log beany Build Logs 34 06-16-2011 06:27 AM
SPL_II's Team CACO Build Log <--- First real Build! SPL_II Build Logs 123 09-23-2010 08:44 PM
Johnathan Price aka 98HOEONSIXEZ 25,000 watt tahoe build log 98HOEONSIXEZ Build Logs 35 08-07-2009 09:38 AM
