My baby has come(SLOW build log) - Car Audio Classifieds!
Old 12-02-2015, 09:18 PM
0/11 ssssss467
Default My baby has come(SLOW build log)
with very minor damange from fedex . none the less im happy so far. I thought the SHD motor was heavey... This thing makes that seem like a toy LOL
Old 12-02-2015, 09:34 PM
0/11 sssssss17
Damn that's a tiny alternator glad you got the sub now though
Old 12-02-2015, 11:30 PM
0/11 ssssss467
yeah i know it makes it look so small lol
Old 12-03-2015, 10:02 AM
umphism's Avatar
0/11 sssssss87
What are the specs of the sub and amp?
Looks very nice
Sent from my SGH-T599N using Tapatalk
Old 12-03-2015, 10:30 AM
Beatdown337's Avatar
0/11 sssss1535
That is a monster woofer....
Old 12-03-2015, 04:46 PM
0/11 ssssss467
amp rated at 9600 wrms at 1 ohm (also underrated 11.5 k board inside) its the m1u series by b2
the subwoofer is a 24 inch custom made. it uses the x2c motor which uses 12 inch diameter magnets 1 inch thick each. 3 in total. it uses a custom 5 inch ceramic coated coil. uses 6 11 inch spiders.. custom tooled spacers and adapters... cone has been re inforced with with glass. 8 inch carbon cone and direct leads. Sub all in all weighs 135+ pounds. Ill post Ts aparamerts later on
Old 12-03-2015, 05:41 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Monster sub, can't wait to see what you do with it!
Old 12-03-2015, 06:59 PM
0/11 sssss1117
You gotta give me a demo. I only live an hr away. Im in allentown pa
Old 12-03-2015, 07:35 PM
0/11 ssssss467
bl^2 / RE at 224
BL on 19.5
RE 1.7 ohm
mms 1000
Zmax 14 ohms,
VAS 165 L
0.8 qts
efficiency is about 90 dB 1 w/1 m
fs 30 hz
Pre break in t/s parameters with the sub sitting directly on the ground which doesnt help being its a vented pole piece
M1u - B2 audio
specs on the amp
the alternator is a mechman elite 370 amp. Might do a second one down the road. Im considering doing an single xs36kspl battery being id only need one. price at that point is about the same as 5 -6 agm batteries. will also being using 4/0 gauge knuconeptz wiring. Highs im still not 100% on. i know im using b2 hn 10 v3s in the front doors as midbasses but which 3 way components idk yet?
this is a daily driver NOT a fart cannon.
box ill prolly do a 6th order series tuned but thats not set in stone
all getting put in a suburban
Old 12-03-2015, 09:48 PM
umphism's Avatar
0/11 sssssss87
That is one bad ass bitch
Nsv3 18s full excursion slow mo baby! massivespl Car Audio Videos 8 10-02-2015 07:44 PM
2012 Subaru Legacy Slow Log Thelonewolf Build Logs 10 09-05-2015 10:54 PM
Wall, Subs, Loud? A Painfully slow build log. btsteinb Build Logs 17 05-03-2015 07:06 PM
Build log:Round 2-Super Slow Motion jheist1991 Build Logs 29 06-18-2014 11:07 PM
Build log of my viberator!!!! Oh yeah baby i like it nasty!!! [email protected] Build Logs 71 01-06-2011 10:33 PM
