2012 F-350 CC LB 4x4 DRW Build Help - Car Audio Classifieds!
Old 12-10-2015, 11:09 AM
0/11 ssssss452
Default 2012 F-350 CC LB 4x4 DRW Build Help
I would like some opinions on my front doors. I will be using CDT ES-06+ and a pair of CDT ES-4. I could Glass the drivers in the stockish location, I could put the ES6top in the stockish location, then seal the pocket area and mount the ES4s. Or I could seal the top pocket area into 2 separate compartments and mount the drivers i9n that area. Would the bodies be blocking the drivers to much? I'm using Zapco DC series amps with DSP to help and the sail panels will have CDT ES-010WD tweeters mounted there. Here are some location pics. Here is the door closed
Missin Texas
Ford Ranger 4x4 Build Log danny1mmafan Build Logs 12 09-07-2014 02:29 PM
New 2012 Build (SQ) Beerdrnkr Build Logs 91 12-04-2013 08:04 PM
Fiji24's 2012 build fiji24 Build Logs 45 12-18-2012 09:31 PM
Hatch's 2012 Build hatch216 Build Logs 4 02-21-2012 10:41 PM
1998 4x4 GMC Sierra Build 98GMC Build Logs 19 03-18-2011 06:57 PM
