highs on bass malibu build - Car Audio Classifieds!
Old 05-01-2016, 09:44 PM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
Default highs on bass malibu build
this will be a little slow going, some a little better later i hope, got some done, some not lol...
details: 2015 Chevy Malibu 2.5L
Sub: Sundown audio X12 rev2 dual 2
Amp: nothing yet*(stand in skar1500.1)
Vocals amp: crunch pzx1800.4
Mids: crunch and autotek 6.5 components
Vehicle has 20% tint all the way around, and a 6 inch 5% strip.
box is 2.5 tuned to 30. with right at 17 sqinches of port / ft
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 05-01-2016, 09:52 PM
I'm F*CKIN Sexy!
0/11 sssss2132
A few more pics
Old 05-02-2016, 12:58 PM
I'm F*CKIN Sexy!
0/11 sssss2132
had some time to play with tuning on the amp today, def gets down, need to tweak the upper range a little bit, but does a great job, I have hood flex, slight window flex, and tons of trunk flex at the moment, it will be turned around, sealed off and a proper trunk wall. then i'll be building the trunk in, hope to raise the floor of the trunk up about 3-4 inches, so that the box sits level. being that the opening of the trunk has a raise to it. and with that, i'll still keep all the room in the trunk spare wheel well, and be able to put a few batts in there, and use the raised height to mount the sub amp's and vocal amps, and clean up the wiring.
Sealed 152.9
Outlaw 156.6
Old 05-02-2016, 01:41 PM
0/11 ssssss150
What part of Atlanta are you in?
Old 05-03-2016, 07:18 AM
I'm F*CKIN Sexy!
0/11 sssss2132
tucker/norcross
Sealed 152.9
Outlaw 156.6
Old 05-03-2016, 12:50 PM
Looks good! What are those yellow boxes under the hood?
Old 05-03-2016, 12:58 PM
massivespl's Avatar
0/11 sssss8409
Ballast for headlight is my guess
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 05-03-2016, 02:00 PM
I'm F*CKIN Sexy!
0/11 sssss2132
You are correct they are my 8k hid ballast 55watt
Old 05-03-2016, 03:06 PM
I'm F*CKIN Sexy!
0/11 sssss2132
well, sub is still stiff as can be, but its doing great, i'm loving it more and more each day, its getting louder and louder.
Sealed 152.9
Outlaw 156.6
Old 05-04-2016, 02:36 AM
Ahhh thanks. For a minute I thought they were passive crossovers, lol.
BHE Malibu build - 2011 Malibu with 2 DC Level 4's and a BC3500 iamamp3pimp Build Logs 4 07-19-2012 01:11 PM
HIGHS ON BASS BUILD LOG epic Highs On Bass Build Logs 377 04-15-2011 09:56 PM
05 Malibu. Tear down and Re-build. DC and RF slapuhho Build Logs 136 10-10-2010 01:07 PM
Door panel build for Highs on Bass Ami Creations General Car Audio Discussion & Questions 22 08-15-2010 01:10 AM
pieper's Malibu Build Pieper Build Logs 0 04-13-2010 09:41 AM
