prototype/buildhouse testing - Car Audio Classifieds!
Old 06-06-2016, 12:02 AM
bassfreak's Avatar
0/11 ssssss597
Default prototype/buildhouse testing
sorry if this isn't the correct section mods i figured its as good as any other
So i been prototyping for a few years now as a hobby and always was interested in designing my own woofers. Thought it would be cool to have something unique and something i designed.
needless to say over the years I've tried a few build houses and liked them. This time around i wanted something more custom/unique. and its based on low distortion and high displacement. everyone has their topology/design this is MINE.. I contacted a few build houses and ultimately found one.
I opted first to keep mass as low as possible unfortunately its higher than i wanted but its fine becasue its not terrible and the cone is very very strong. wanted to get very low inductance and to make the design as linear as possible without having a stupid price tag(otherwise i would have done the CF cone).
I opted for a longer coil. A 4 layer coil to save on mass and increase surface area by using a long coil all while keeping the inductance down and frankly low as possible. (1.56mH, coil mass is under 100 grams!)
one flaw to the design this is needing a LARGE top-plate to increase BL to a usable level. Its taken a few prototypes and time to get it where it is but it sounds GREAT. the original driver had stacked spiders and the former had no holes. so i opted to recone it and get another coil wound on a vented former and to space the spiders to prevent rocking/rubbing becasue the top-plate and coil/former is so long and gap is so tight. it will be reconed in a week or two when the parts come in and i have time. It's rated for 2kw RMS.. I'm going to run it on 3.5 for testing. some of the draw backs to this design are the damn thing is HUGE in order to get the motor strength.. It will handle 3kw and sounds EXCELLENT for a driver capable of 33+ mm Xmax and taking 3kw daily.
I personally love the high output low distortion drivers(ill admit i LOVE the JBL GTI and XXX/barhma) and this woofer is right up my alley. Anyways im gonna post a few pictures of the driver and i have one of the coil/former.
The original prototype i tested on a TS 3500 @ 1ohm in a 3.5 cubes tuned to 32 with 35in^2 of port area(way to small and not enough port area). The gain was set according for the initial testing and it handle 3kw with ease. Then i said **** IT TURN IT UP!!! its still alive but it was clipped pretty damn good.. i hear a little rub when i push on it but it plays fine with no noise. haha. so i changed a few things to improve the cooling/reliability.
once the recone is done its going into 4.25 tuned to 35 with 70in^2 of port area for more listening and torture testing. I've flirted with the idea of doing a production run but im not exactly sure if i will or not. The market is flooded and the economy has stunk for a few years now but hell i might just take a leap and try. if anyone is interested just let me know..
@MASSIVESPL dont come spout about the driver if you dont know the facts. i don't care if you have criticism or if you dont like me but its NOT A CLONE ITS NOT COPIED I DESIGNED IT with a little help from the build house becasue they have the FEA and programs which i can't afford so unless you have proof im coping something/one fine! which you never will becasue it doesn't exist!
the revised former/coil with the cooling vents to help dispurse more air around the coil/gap.
Next to a HDC3 15
Again
shot of the coil/former
dual leads per coil 10" spiders these where sandwiched not spaced(build house said it was a mistake) so im going to use spacers to fix that..
excited about testing it. the original sounds like a GTI on roids. it was loud as hell and sounded transparent at those levels. its not a fart woofer its meat to sound excellent and will be a great streetbeat driver. its capable of handling 3kw in 4.5 cubes and having SICKING lowend while sounding as good as any driver designed to do so. of course your going to get some fairly high group delay in this alignment but in the correct alignment the group delay is below the human threshold..
comments and criticism welcome just make damn sure if you criticize you can back that shit up..
Old 06-06-2016, 12:09 AM
Souldrop's Avatar
0/11 sssss1270
What's the diameter on the slugs?
2016 Scion iM
- Bone stock for now
Old 06-06-2016, 12:13 AM
bassfreak's Avatar
0/11 ssssss597
255mm
The Following User Says Thank You to bassfreak For This Useful Post:
Souldrop (06-06-2016)
Old 06-06-2016, 12:25 AM
0/11 sssss3526
Looks like a beast
Team Flex Issues
Temp build
Jvf Custom ssx 12 on DSC 1500
Xs Power
Hertz/Image Dynamics
Old 06-06-2016, 01:33 AM
0/11 sssss1085
Feedback Score: 23 reviews
Are you willing to share the info on your motor design to flatten bl and the le(x) curve?
Old 06-06-2016, 02:05 AM
bassfreak's Avatar
0/11 ssssss597
honestly its a typical LGLC design. the BL is pretty much flat out to 25mm and standard xmax as defined by dumax specifications is 34mm. the coil was just wound with low inductance in mind. the coil will almost never surpass 28mm(90% of the gap height) with 3kw on music so even though its a typical LGLC design its still very linear in stroke on rated power.
its nothing special just carefully designed after many attempts, lol
i'll post up the parameters..
Old 06-06-2016, 06:04 AM
0/11 sssssss17
Looks damn nice! What soft parts?
Old 06-06-2016, 06:50 AM
bassfreak's Avatar
0/11 ssssss597
5 10" progressives nomex.. a big ass high roll surround. Lol
Its the thickest non pressed paper cone they had and a very hard poly dustcap. It is the hardest nonfiber dustcap I've seen yet.. over all the build is awesome but they also failed to put the vent gaps. Which is ok because I know it will cool the coil much better if I decide to put them into production.. so far the soft parts seem excellent besides not being spaced..
Old 06-06-2016, 08:01 AM
0/11 sssssss17
That's awesome man. Keep it updated forsure!
Old 06-06-2016, 09:35 AM
0/11 sssss3526
Roughly what would these cost if they went to market?
Team Flex Issues
Temp build
Xs Power
Prototype amp testing. Opinions? Comments? kingsuv General Car Audio Discussion & Questions 96 07-10-2012 08:53 AM
Sundown SA-8 v.2 Prototype Thermal Testing sundownz (Sundown Audio) 13 06-01-2012 07:49 AM
Prototype Z v.3 Testing sundownz (Sundown Audio) 202 01-06-2012 06:16 PM
Sundown Buildhouse RE_XXX General Car Audio Discussion & Questions 27 07-11-2009 05:10 PM
