2000 Lincoln ls install - Car Audio Classifieds!
Old 12-01-2009, 06:55 PM
0/11 sssssss19
Default 2000 Lincoln ls install
here is what I have so far
2000 lincoln ls fully covered with 2 layers of fat mat
mb quart qsc 5 1/4 components with the qsc 164 midbass
focal k2 6.5 comp
diamond audio s600s comps
2 phoenix gold ms275 amps
rd d5(on the way just bought it yesterday)
2 re xxx 12's in a ported box
head unit is a alpine cda-9883
all knu koncepts wire and cables and power
sub box will be right at 6 cubic ft tuned to 32 hz
only thing im not sure of is if I need to make it a mono chamber or give each sub there own airspace any advice would be great
also any advice on the d5 and how it will perform would be greatly appreciated
Old 12-01-2009, 06:58 PM
0/11 sssss9745
Wrong section. Moved to Build log section.
0/11 sssss7816
use one chamber,
Pics!
Atomic Loudspeakers
Audiotechnix
Old 12-01-2009, 09:21 PM
ckaiser1688's Avatar
0/11 ssssss300
yes pics please! im going to be helping my friend with a build on a 2002 lincoln ls so i might have some questions.
HU- Kenwood Excelon x794 : Sub-2 12" Skar VVX
Amp-Sundown SAZ 2500d : 4.3 cu ft box tuned to 30
BEST TL: 142.1 sealed on the dash
Old 12-01-2009, 09:33 PM
0/11 sssssss19
I'm in the process of uploading some pic I am going to build some custom kick panels just not sure which set of speakers to put there.. I have installed the focals in the front doors and the 6.5 mid bass in the back deck.. moved the battery in the trunk to make room for the massive box.
Old 12-05-2009, 02:09 PM
0/11 sssssss19
Old 12-05-2009, 02:14 PM
0/11 sssssss19
Last edited by Patrick Simmons; 12-05-2009 at 02:21 PM. Reason: fixed picture links
Old 12-05-2009, 02:18 PM
0/11 sssssss19
this box is only temparary im building a fiberglass one for the 2 subs that will take up the whole wheel well and I need to put an additional battery on the drivers side of the car... not sure yet what the amp rack is going to look like but I want the ms275 behind plexiglass and the d5(which I hope to get today) out.... the set of mb quart tweeters I am going to put in the pillars by the windshield and fiberglass kick panels for the 5 1/2 mb quarts... I decided to put the diamond audio in the back doors not sure what to do with the hex tweeters yet... any sugestions?
Old 12-05-2009, 02:52 PM
0/11 sssss9745
Looking good, I wanna see how it looks once you fiberglass the trunk. I have the same car, just starting the rebuild for next season.
Bwoodroof's Damplifier Pro Install - In da Lincoln bwoodroof (Second Skin) 12 10-14-2009 09:40 PM
Patrick's 2000 Lincoln LS Build Log Patrick Simmons Build Logs 322 07-12-2009 08:29 PM
Upcoming 2000 Lincoln LS Supercharger project Patrick Simmons General Automotive Chat 22 06-02-2009 06:52 PM
1st install in my lincoln SPY Member Rides & System Pictures 12 08-29-2008 08:27 PM
trade my kinetik 2000 for batcap 2000 Slam Car Audio Trader (WTT) 3 08-22-2008 11:10 AM
