16 15s 4th order - Car Audio Classifieds!
Old 08-03-2016, 10:25 PM
0/11 sssssss20
Default 16 15s 4th order
Ive been messing around with car audio off and on for about 18 years and Ive always wanted to do a big build with a bunch of subs. I finally got around to doing that project. I had an idea in my head and honestly didn't know if it would fit in my s10 but I ordered all the subs so that pretty much decided that. Of course I started the build in the hottest months of the year with no shop. The build started with 16 Sundown Ev3 15s and 2 Taramps HD15000's
Trying to get any shade I bought a tarp and went a little ghetto with it but it worked so that's all that matters.
Start of the shell, decided to use a kreg jig and build it inside the bed to get the most space as I could.
Roof and front face in
Wheel tubs boxed in
First baffle cut making sure I didn't mess anything up already
Both baffles cut for one side, moving along nicely
Checking to make sure I wouldn't have any surround rub issues. I loaded a sub into each hole and put 2 screws in to ensure each sub would be aligned once they were inverted.
Making sure they were going to fit, I was still unsure up until this point.
Other baffle cut and test fitting
Baffles mounted and bracing on the sealed side
Added a little round over
Loading subs!
Got all the subs loaded and bracing in
A view through the back window
I dont have any pictures of how I sealed it off but it was just a piece of birch the shape of the back glass with a port that went into the box. Once I got it playing it sounded insane but didn't do very good numbers because it peaked so low. Best score was [email protected] sealed on the dash. While that looked cool and did nice demos I wasn't very happy. At this point I decided to get something a little bigger so I could get the port opened up and also build a more appropriate box if I wanted to. I bought a 2000 Suburban and started getting it ready. The first thing I did was get the port opened up to the sealed section, went from 344 square inches of port to 835 square inches.
Time to come out
Box in and port opened up, had a few subs down at this point
Time to add some sound
Sealed up and bedlined
After this was my first show which was a huge disappointment, ended up blowing 5 subs. Apparently the E's don't like 1500 watts per sub lol. So it was time to pull them all and think about how I wanted to move forward. I had a lot of time and money in the box so I decided to stick with the plan and ordered 16 SA 15's
Empty
While waiting for the new subs to arrive I decided to build a proper amp rack instead of having the amps just screwed to the floor in the back.
First things first started with a battery box
Decided to duct the rear a/c into the amp rack to keep the amps cool
Forgot to take pictures along the line here but after a little bedliner
You can see the ducts here
Amps mounted
New subs loaded
Next show went a little better, got loudest average of the day with a 155.93. They do a 15 second run in the floor, 30 second run on the windshield and a 45 second run at the headrest.
I still have work to do, my voltage is dropping to 10.8. I only have 4 g31's and 1 300a alt. Its burping a 158.6 in the floor now and I feel like when I get the voltage where it needs to be it should do a 160. I don't have any interior mods either so I think I will be able to get it pretty loud. The box isn't really ideal, sealed sides combined are 20 cubes and ported side is 31. Here is a shot of the truck and thanks for reading my post.
Old 08-03-2016, 10:32 PM
0/11 sssssss20
Not sure why all my pictures aren't showing up, maybe too many for one post? Ill fix it tomorrow.
The Following User Says Thank You to 90talontsi For This Useful Post:
chasinbass (08-03-2016)
Old 08-03-2016, 11:28 PM
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Looks good from what i can see!
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 08-04-2016, 08:55 AM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Sixteen Fifteens...
That's just crazy to say...
Sent From My Phone
Old 08-04-2016, 10:25 AM
0/11 ssssss543
Any idea what the sealed resonance is? Is honestly but a wt3 just to do impedance sweeps to find your peaks possibly drop a sub from each side to get it where it needs to be.
Old 08-04-2016, 11:10 AM
0/11 sssssss20
I'm not sure on the sealed resonance. I should only need to know that if I'm going to add a loading wall, right?
Old 08-04-2016, 11:23 AM
0/11 ssssss543
Your port is your loading wall. Your sealed resonance is very important in 4th orders. It might be as simple as adding poly til to get it where you want it or as bad as a full rebuild. Your goal is a resonance in the 40's with a matching tuned ported side. Switching subs will change this as well so the wt3 is nice to have at only $100 it's worth it when trying to get the most out of many thousands of dollars worth of equipment.
Old 08-04-2016, 11:34 AM
0/11 sssssss20
I've looked at the wt3 before, seems like a really valuable tool. Thanks for the advice.
Old 08-04-2016, 02:23 PM
doug118's Avatar
0/11 sssss4674
technically you won't have a port. keep that in mind
Old 08-04-2016, 03:04 PM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2084
Feedback Score: 32 reviews
Holy Huge Pictures!
Sweet Build(s) man!
4th order for 2-x-15s davidrforbus Enclosure Discussion & Design Construction Help 2 05-18-2015 08:52 PM
4th order for k9 15s b4ss_h34d Enclosure Discussion & Design Construction Help 0 07-28-2014 12:05 PM
2-4th order designs for 4-15s. Which one? stssilverado Enclosure Discussion & Design Construction Help 2 02-15-2014 08:06 PM
6 sa 15s 4th order help!!!! cnb.agb General Car Audio Discussion & Questions 15 01-08-2013 10:22 AM
8 15s in a 4th order. Corey J Car Audio Videos 17 07-17-2012 04:48 PM
