Small Duramax Build, Nothing Major - Car Audio Classifieds!
Old 09-06-2016, 09:01 AM
nkrell11's Avatar
0/11 sssss1420
Default Small Duramax Build, Nothing Major
Hey guys I picked up a truck this spring it was time for an upgrade and I plan on doing a small build nothing major. Most of the upgrades will be under the hood, truck was basically stock when I got it except for the leveling kit, wheels and tires, and an exhaust. Since I bought it I have installed, HSP cold side egr delete pipe, modified up pipe, MBRP 3" downpipe, Deviant Race Parts PCV reroute, Fass 150 lift pump, Beans Diesel sump, Fass fuel filter delete, PPE race valve, PPEI DSP5 Tuning, Edge Insight CTS2, Cognito upper control arms, PPE tie rod sleeves, and Bilstein 5100's up front. I have a shift kit, and HSP hot side pipe that I haven't gotten around to installing new wheels are on order since I didn't want to deal with maintaining chrome.
As far as the audio goes going to be doing 2 Sundown SD3 10's, Cactus Sounds PF300.1, probably a positive and negative run of Shok 1/0 since I have bunch left over and a JL Audio Cleansweep. I wanted to retain all of the bose stuff and steering wheel controls. I only drive a few days a month so trying to keep the install as budget friendly as possible. Anyhow all comments are welcome this log won't be very extensive but at least it will have pictures.
The truck
Cold side pipe where the EGR used to be.
Front end suspension work from last weekend before and after.
Gear
Jeep Build Log:
Daily (Rebuild Pending)
Old 09-06-2016, 09:10 AM
nkrell11's Avatar
0/11 sssss1420
Alright so onto what I did this weekend, I built the box mostly out of the box from my grand prix build that I tore apart which is why it's mostly Birch. Didn't have a piece big enough for the top so I bought a sheet of MDF. The box isn't perfect but I don't usually do stuff with so many angles. If I had to do it again there's some things I'd have done differently but oh well I'm pretty happy with how it turned out. It was mostly trial and error getting things to fit which made it take longer. All these pictures are basically what I accomplished on Sunday.
Jeep Build Log:
Old 09-06-2016, 09:18 AM
nkrell11's Avatar
0/11 sssss1420
All if these are yesterday's work my girlfriend did most of the painting, inside and out. I anticipated having clearance issues so that's why the box has a couple of windows. I could have used wood but I had the extra plexiglass glass so I figured why not. Getting the top to fit was the worst because of the angles and the box managed to get a little out of square when I was building.
I suck at cutting straight lines with a jig saw.
All painted up what it will look like with the subs in.
Not the best picture but here's how it looks in the truck with part of the seat folded up.
Overall I like how it turned out, I may try and lift the seat about a quarter of an inch as it rubs the box a little when you fold it down. Hopefully my amp will mount behind the seat as I have no other place for it. Of everything goes well I will have everything installed next time I'm home.
Jeep Build Log:
Old 09-06-2016, 11:27 AM
0/11 sssss3526
Nice lookin truck
Old 09-06-2016, 12:10 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
Nice mods all around how does the audio sound? Box looks nice
Old 09-06-2016, 01:16 PM
nkrell11's Avatar
0/11 sssss1420
Thank you sir as of now I don't have any audio installed, app I had time for this weekend was the box build.
Jeep Build Log:
Old 09-07-2016, 06:47 AM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
My bad I misread but still tuned in!
Old 09-07-2016, 07:00 AM
nkrell11's Avatar
0/11 sssss1420
With any luck I'll have everything installed the first week of October, as I'm going to be in Kansas for work until then.
Jeep Build Log:
Old 09-07-2016, 09:18 AM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2084
Feedback Score: 32 reviews
Looking good, man.
Old 09-07-2016, 06:55 PM
nkrell11's Avatar
0/11 sssss1420
Originally Posted by colorblind83 View Post
Looking good, man.
Thanks there wasn't really much out there to base my build off of so I just came up with a general plan and went with it.
Jeep Build Log:
A Few Questions Pertaining to an Install in my Duramax. nkrell11 General Car Audio Discussion & Questions 5 06-24-2016 01:23 PM
2015 silverado duramax setup BIG_SUPERMAN72 General Car Audio Discussion & Questions 0 06-03-2015 06:23 PM
Major Small Issue with the Amplifier Tkelly260 General Car Audio Discussion & Questions 5 09-30-2012 12:08 PM
Small bass package for power wheels build or small daily setup jjffy6 Car Audio Packages 10 10-10-2011 12:08 PM
2006 sierra duramax 6.6L alt dylan9999 General Car Audio Discussion & Questions 1 11-16-2010 10:42 AM
