2016 fiesta B pillar - Car Audio Classifieds!
Old 11-15-2016, 11:27 PM
0/11 ssssss535
Default 2016 fiesta B pillar
Hey guys just thought I would share some pictures of a build I'm lending a hand with. Progress will be slow as I don't have much free time so it's hard for the owner and I to coordinate time to get work done on it.
-2016 Fiesta (bought solely for this build)
-3x DDZ 18s
-DD Z2C amp
Still deciding on batteries, will probably be lithium, and hopefully we can fit 2 alts in this tiny engine bay.
Here is the progress so far.
One of the subs.
The Following 2 Users Say Thank You to chance_p For This Useful Post:
colorblind83 (11-16-2016), iamsonic (11-15-2016)
Old 11-16-2016, 12:23 AM
0/11 sssss3526
Must be nice to buy a 2016 strictly for a wall build lol
Tuned in
Old 11-16-2016, 01:25 AM
knowledge's Avatar
0/11 sssss2548
very good start but more pics please
Old 11-16-2016, 08:38 AM
Highs On Bass's Avatar
I'm F*CKIN Sexy!
0/11 sssss2132
tuned in as well!
Yep... I'm an AMI NUT HUGGER>.. HE's the master of my wood
Current scores to date as of 12/5/2010:
Sealed 152.9
Outlaw 156.6
Old 11-16-2016, 12:25 PM
jheist1991's Avatar
0/11 sssss1070
tuned in. Chance, is this a local-ish guy?
Old 11-16-2016, 12:59 PM
0/11 sssssss33
Tuned in
Old 11-16-2016, 01:03 PM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2084
Feedback Score: 32 reviews
NICE!!
Old 11-16-2016, 02:34 PM
0/11 ssssss535
We will probably get started on the enclosure in the next few weeks. I finished up the roof and I have the floor of the enclosure cut. The next steps are...
-cut out a portion of the rear decklid.
-potential welding to re-strengthen what's left of deck lid
-bolt in the floor of the enclosure and fill underneath with foam
-build the baffle
We already re-routed all of the fuel pump/evap/abs wires so they won't be "trapped" under the enclosure. I need to add an access hole to the floor of the enclosure incase the fuel pump ever needs changed.
The baffle will be slanted, with a sub in each lower corner and then one in the center sitting down in-between the outter woofers as low as possible. If we stack them touching each other they center sub will be right at 25" high. We have a max of 32" though so there will be space between the woofers to make it look nice.
The port will be a slot that will be as wide as the roof and about 5.5-7" tall. Ill basically be building a sealed enclosure for the subs first, then the slot will exit through the top of the enclosure and travel over the top of it and finish flush with the edge of the slanted baffle. The top of the port will be another layer of 3/4" attached to the roof, and then I'll just need to make some sides to put between the enclosure and the roof. It should come out very clean, and the port will flow almost perfectly into the roof up front.
There will also be an array of mids and highs on the side of the enclosure that will be exposed when the rear windows are rolled down.
Old 11-16-2016, 02:38 PM
0/11 ssssss535
Yeah, he's the owner of a shop in town.
First car audio get together of 2016 massivespl Car Audio Videos 0 03-12-2016 07:35 PM
2016 US Acoustics Pricing denim (SSA) 0 02-02-2016 01:31 PM
American Bass HD 15 Build - Ford Fiesta Trunk Box XORstatus Build Logs 0 09-22-2015 08:03 PM
2016 magnetar Quentin Jarrell Direct Sound Solutions 14 02-15-2015 06:18 PM
