NSv3 15s and supercap fun - Car Audio Classifieds!
Old 11-27-2016, 07:30 PM
So Low's Avatar
0/11 sssss1258
Default NSv3 15s and supercap fun
So I bought a few new cars for myself and the wife, and I don't plan on doing anything new with my current system vehicle, so I decided to take my wife's old Jeep Liberty and have some fun with it. Biggest problem with the build is space, so I took my time deciding how to get the most bass with the least space. I ran the numbers over and over and came up with a few good ideas only to find flaws in each of them. I finally came upon two 15s in very tight quarters to accomplish what I was looking for bandwidth wise. Only a few woofers out there that could operate in the space I had so I opted for some NSv3s mostly to avoid wait times on new woofers. Even more of an issue was finding the power to run everything in such tight quarters, and cutting down on weight. Agm batteries was out, I almost pulled the trigger on lithium batteries but ultimately decided caps would have to do the trick. On to the pics
Some goodies:
Subs:
Closeups:
4/0 and 2/0 cable throughout. Two runs positive and two negative front to back.
Side firing port was the final design:
Opted to try a different arrangement with the caps:
Few more touches
Wiring is tiring
Lining up the pieces
Mids and highs
More wiring
Mocked up a false floor
Charging up the banks
Quick paint job that needs some work yet
Some heavy lifting ahead
No headrests to block my view
I got a decent amount of listening but not enough so far. The bandwidth is perfect to my taste, and the voltage is unbelievably solid (14.4-14.5) and it sounds good overall. I took some video, and will take more in the near future. I'll be sure to share
Old 11-27-2016, 07:51 PM
doug118's Avatar
0/11 sssss4674
If all you're running is that single 6500, you'd only need a single bank of caps and that alternator to keep the voltage above 14v.
The Following User Says Thank You to doug118 For This Useful Post:
chrishxc718 (11-29-2016)
Old 11-27-2016, 07:56 PM
So Low's Avatar
0/11 sssss1258
Just the 6500. For now
Old 11-27-2016, 10:00 PM
jigsizzle's Avatar
Jet Life
0/11 sssss2274
Looks great man...
Sent from my SAMSUNG-SM-G530AZ using Tapatalk
Old 11-28-2016, 09:52 AM
0/11 ssssss225
Pretty sweet How does someone determine how many of those super caps to use?
Old 11-28-2016, 03:33 PM
So Low's Avatar
0/11 sssss1258
However much money you have divided by $44 for the 3000F versions. In banks of six for the 2.7V model too so buy in multiples of six
Old 11-28-2016, 03:45 PM
So Low's Avatar
0/11 sssss1258
http://youtu.be/cKlb7NYYHTw
It's weird not having 14V batteries but I'm ok with this amount of drop so far
Old 11-28-2016, 03:54 PM
0/11 ssssss225
So it doesn't mess with the amp that the caps voltage would add up to 16.2 for 6 of them? Also is there a for sure way to figure out how many you'd need? For example I'm running a scv4000 what would I need?
The Following User Says Thank You to Jski1990 For This Useful Post:
tp1182 (12-13-2016)
Old 11-28-2016, 04:18 PM
So Low's Avatar
0/11 sssss1258
One of the cool things about caps is they can be charged up to their rated voltage or lower, so each cap in my bank is only sitting at about 2.4V. They also deliver power at all voltages, where typical agm batteries drop to 13V or below when they deliver high current.
Some amps like high voltage, some are ok with lower voltage, but they all need to see an appropriate amount of current to make power. With that SCV 4k you can see a bit of voltage drop and be ok, you could probably get away with one battery and one bank of caps and be good depending on how good your charging system is. I'm a sucker for overkill so it's hard to say what you need at a minimum. But try one bank, and see how far you can turn the knob until the voltage drops out of your comfort zone. If you make it all the way , cool. Then you know
The Following User Says Thank You to So Low For This Useful Post:
Jski1990 (11-28-2016)
Old 11-28-2016, 04:25 PM
0/11 ssssss225
Ok thanks! I'm running it off 2 xp2500 batts but I was curious because I'm going to try putting my system into my tiburon in the spring but I don't think I'll have the room for the batteries.
tp1182 (12-13-2016)
BRAND NEW Sundown NSV3 15s DUMPED 15" Subwoofers 15 10-27-2016 07:55 AM
Supercap strawsy General Car Audio Discussion & Questions 13 04-06-2016 04:37 PM
160.5db on 4 nsv3 15s massivespl (Sundown Audio) 34 10-20-2015 09:48 AM
What would be louder 6 sa 15s or two nsv3 18s on same power. Mnorwood01 (Sundown Audio) 38 02-23-2014 10:56 AM
What has more potential to be louder three zv4 15s or two nsv3 18s Mnorwood01 (Sundown Audio) 14 12-18-2013 08:34 PM
