Project Sandy - 07 Altima Sundown build - Page 2 - Car Audio Classifieds
Go Back   Car Audio Classifieds > Car Audio Help & Discussion > Build Logs
  #11
Old 02-15-2017, 08:39 AM
350zkid's Avatar
1/11 sssss1560
Feedback Score: 46 reviews
Looking for ideas for my 2013 also! Nice stuff!
Old 02-15-2017, 11:50 AM
enemyofsilence's Avatar
1/11 ssssss350
Originally Posted by Austin175 View Post
Have you tried firing forward an sealing it off into the cabin?
That's what I intend to do here with this new box hoping it will help!
Originally Posted by Sake. View Post
2013 Altima here. I have the same setup in my spare tire well, except with only one d34. Hows the car performance and sag with the two 31s?
Keep up the good work
Its not too bad with the 2 batts in the back. I felt like my old mdf enclosure made it sag more than having the batts there. And thats why I choose lighter wood to prevent even more sagging once everything is in there
Team Bass-Hz
  #13
Old 02-22-2017, 12:01 PM
1/11 ssssss350
Got some more work done this past weekend. First my subs came in and oh myy
Pair of Zv4's Rev 2 with Nightshade coil and spiders. Triple tinsel leads and carbon fiber caps? Don't mind if I do!
Team Bass-Hz
  #14
Old 02-22-2017, 12:06 PM
1/11 ssssss350
Decided to keep the batteries in the spare tire well so hooked up all the wires and secured the batteries from moving around.
First got my leads prepped from my fuse block to the batteries. All 4/0, love how they fit so snuggly
Team Bass-Hz
  #15
Old 02-22-2017, 12:14 PM
1/11 ssssss350
Since each sub has its own chamber, I decided to wire each sub parallel and then have a lead from each one to connect to the amp. All Sky High 8awg speaker wire ftw, final load for the amp at 0.5ohm
How the box currently sits, will end up pushing it more towards the cabin and cleaning up all the mess that can be seen. Just couldn't wait to get her connected and playing!
Team Bass-Hz
  #16
Old 02-22-2017, 12:15 PM
1/11 ssssss350
Now just waiting on new rubber gaskets and some Sundown logo decals to put on the dust caps but she's already bangin! Will post up a vid soon
Team Bass-Hz
  #17
Old 02-22-2017, 12:20 PM
IBleedMusick's Avatar
1/11 ssssss415
Looking good, tuned in
  #18
Old 02-22-2017, 12:24 PM
1/11 sssssss17
Looking awesome.
Are you going to seal it from the trunk? I used huge shipping foam on the sides and gorilla tape on the top. I'd show you photos but the box is out atm since i'm wiring the front stage amp to the rear battery
  #19
Old 02-22-2017, 01:10 PM
1/11 ssssss350
Yea planning on sealing from the trunk. And will keep that in mind, I've heard shipping foam, pool noodles and thick foam cushion works so I'll see what I use haha. I'm thinking of using mdf as my walls and then sealing it with a type of foam material. Don't want to use foam spray tho and get everything messy!
Team Bass-Hz
  #20
Old 02-22-2017, 01:18 PM
1/11 ssssss415
I just used really tight wood panels in my Civic pressure fitted around the box and made sure there were no cracks in between them and by the time I wrapped the panels it was completely sealed from the trunk. Best part was tear down was simple and clean.
The Following User Says Thank You to IBleedMusick For This Useful Post:
enemyofsilence (02-22-2017)
In order to be able to post messages on the Car Audio Classifieds forums, you must first register.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mtrevino92
2007 Nissan Altima Build Log Ryan1126 Build Logs 102 03-25-2013 11:55 PM
20cube 4th order Altima build LyferXB9s Build Logs 330 08-19-2011 04:39 PM
2008 Nissan Altima Re-Build gbo559 Build Logs 63 08-22-2010 03:42 PM
08 Altima Couple Build RidnClean Build Logs 13 08-10-2009 08:19 AM
Kiddie BS + sandy vag's as usual scruffy daddy Off Topic Chat 59 06-12-2009 09:16 PM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Guest
