Horns Bazookas & SI DS4 18 SQ FTW! - Car Audio Classifieds!
Old 05-25-2017, 09:54 PM
onebadmonte's Avatar
0/11 sssss1221
Default Horns Bazookas & SI DS4 18 SQ FTW!
Greetings and salutations beings of the internet. I come bearing random thoughts ramblings and a build log. This will be version 3 of my 2004 suburban. The setup:
Sony XAV-701HD
Stevens Audio Full Size Horns
Beyma 8BR40 8" Mids
Arc PS8
Bazooka MGA series Amps
Stereo Integrity DS4 18 sealed 6cuft
This is also the simplest iteration. I employed the KISADUWDATTDT method: Keep It Simple And Don't Upgrade When Done And Tune The Damn Thing. Just a little FYI the horn install happened a few years ago. This a compilation of a build that spanned a few years. :P
Up first are the horns. You've seen one you've seen them all but just in case here is a pic.
I designed in CAD and had CNC plasma cut some brackets.
I did a little prepping of the horn bodies before installing.
Here is the passenger side mocked up in place.
The final install.
For those who can get enough pics here is a link to more:
Horn Update Slideshow by onebadmonte32 | Photobucket
Stay tuned for moar updates.
The Following 2 Users Say Thank You to onebadmonte For This Useful Post:
colorblind83 (05-26-2017), nadcicle (05-26-2017)
Old 05-25-2017, 09:56 PM
0/11 sssss1221
I made some kick pods that can actually be kicked, but I won't appreciate it if you do it intentionally during a demo. :P
This is the vision with the little Beyma 8BR40 in place.
Layed up some glass.
Made some kick ass rings with some simple steel mesh grills. I'm using some threaded wood inserts and 8-32 button head cap screws to hold everything down.
After some blood, sweat, and many many many tears I got some pods made.
After a fresh coat of rubber undercoating I mounted the pods to the kick panels.
The final install
More pics can be seen here:
Kick Pods Story by Hugo Ramos (onebadmonte32) | Photobucket
Moar updates coming up.
The Following User Says Thank You to onebadmonte For This Useful Post:
Old 05-25-2017, 09:57 PM
0/11 sssss1221
And now for a little bottom end brought to you via a Stereo Integrity DS4 18.
Freshly cut wood.
I'm using a textured piece of abs plastic one the baffle for a little something extra.
Box with a pair of Bazooka MGA1100h strapped (2KW) to the 18. Boom!
Bazooka 4 channel, Arc PS8 and Stinger wire goodies.
A little carpeting action.
Finished product.
Pics for those that gotta have moar!
Sub Box Story by Hugo Ramos (onebadmonte32) | Photobucket
Thanks for looking.
0/11 sssss1221
Got me a little something extra for the PS8.
Drew me up a little housing to mount in the dash.
Laser cut FTW!
Formed and welded.
Cut some mounting ears and welded some flanged nuts using works tig.
Used my crappy flux core mig at home to eff everything up.
The final install
For more behind the scenes pics:
PS8 Pod Story by Hugo Ramos (onebadmonte32) | Photobucket
Thanks for looking.
Old 05-26-2017, 09:01 AM
209native's Avatar
0/11 sssss1975
looks great man!
prs 80 hu
brovax cf 5.25 comps
hertz mille 6.5s
2 stinger 1700s
mechman 320
rebuilding
The Following User Says Thank You to 209native For This Useful Post:
onebadmonte (05-26-2017)
Old 05-26-2017, 09:41 AM
0/11 sssss1221
For those interested in the history of my shenanigans here you go.
Version 1
Kicker Warhorse vs. Two DD9515s o_o
Version 1.5
Will it blend? Warhorse vs JBL w15GTi'z
Version 2
A Suburban A Warhorse and a Pair of SMDeez
Old 05-26-2017, 02:34 PM
nadcicle's Avatar
Resident Troll
0/11 ssssss184
Did your Suburban have that stupid ebrake release right in the middle of the underside of your driverside dash? I know it comes off with a couple of screws, but I thought it left a little indention and I don't see one at all on yours. I am interested in those brackets you made for your bodies as well. Any chance you saved that file and would be willing to reprint pending on if they'd fit my escalade 05.
97 Suburban Nothing for now
05 Elantra Two 18" Custom DB Revolution Neo's
MECA 2013 TN Street 3 Champion
MECA 2014 Dueling Demos Street World Champion
Old 05-26-2017, 02:39 PM
0/11 sssss1221
It did have the release next to the OBD diagnostic port under the driver side dash. I took it all out the parking brake and the release and relocated the ODB diagnostic port to the fuse panel area on the driver side dash. I do have the file available if you need a .dxf to have someone cut for you. If you need a pair cut we can work something out.
Old 05-26-2017, 02:53 PM
nadcicle's Avatar
Resident Troll
0/11 ssssss184
Last time I took 2 peices of wood and put a piece of lexan between them in a vice and used a heatgun back and forth and while applying a bit of pressure and then used a dremel to notch it out. It worked, but metal looks a bit better. I have a pair of full size old school ID ultras that I'd like to use that are burning a hole in my head along with this helix pro. I will ask a friend first before getting the file from you btw. I don't want to assume he will do it, but I think he will. Thank you!
The Following User Says Thank You to nadcicle For This Useful Post:
Old 05-26-2017, 02:57 PM
colorblind83's Avatar
drug mule for speakers
0/11 sssss2084
Feedback Score: 32 reviews
Sweet install!
I'm really digging them waveguides.
If I were gay I would marry you.
Funny how a girl stops talking to you when you say you would rather be homeless and give her nothing than have a kid...women...
The Following User Says Thank You to colorblind83 For This Useful Post:
Question about Stereo Integrity DS4 18's DevinG17 General Car Audio Discussion & Questions 3 09-12-2016 02:24 AM
Stereo Integrity's new DS4 -18. 4" coil sub under $280 shipped. williamhung General Car Audio Discussion & Questions 46 05-05-2016 06:22 AM
ID Horns MasterMod eBay 0 07-26-2011 11:51 PM
GetLikeMe's NEW AMP!!! FTW GetLikeMe General Car Audio Discussion & Questions 72 03-25-2011 11:23 AM
[MODERATE] How To: Piece Together & Install Air Horns danteBirosel Tutorials & Quick References 0 11-12-2008 02:18 PM
