ABC 4th Order Build - Car Audio Classifieds!
Old 12-26-2009, 01:17 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
Default ABC 4th Order Build
sounds interesting
we'll see results of this experiment soon.
92 Ranger Walkthrough
(Under Construction)
Old 12-26-2009, 01:20 AM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
only question i have is. why is there a second chambered section if there isnt a sub going in there or air passing thru?
and if it doesn't work you can use it for a maze if you ever decide to get mice
Old 12-26-2009, 01:21 AM
because it's an abc box there is a tutorial I put up in the section
Old 12-26-2009, 01:22 AM
30Hz
0/11 sssss6601
oh shit lol NVM i looked at the 3rd pic i see it splits into 2 different chambers im blind!
Old 12-26-2009, 01:23 AM
30Hz
0/11 sssss6601
im gonna go read it looks interesting
Old 12-26-2009, 01:25 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
i made a ABC box before and its been the "loudest" so far.
Old 12-26-2009, 02:44 PM
Man Behind the Curtain
0/11 sssss1699
Interested in seeing how this works out.. Nice to see your trying new ideas.
Old 12-26-2009, 02:58 PM
0/11 sssss5305
how do you seal off the top panel since the sub has to be installed before it goes on? Something like caulk or silicone that won't make a permanent bond?
I looked into the ABC box a few years ago, but never found time to try one. Look forward to some results.
Old 12-26-2009, 03:04 PM
RidnClean's Avatar
Ballin
0/11 ssss17858
yeah probably lay down some caulk or somethin.
screws should make it pretty damn tight down as it is.
The Following User Says Thank You to RidnClean For This Useful Post:
fomfan567 (04-10-2011)
anybody done a 4th order in an suv? toolmaker Enclosure Discussion & Design Construction Help 2 12-14-2009 09:32 PM
4th order help mcbuggin Enclosure Discussion & Design Construction Help 0 10-25-2009 12:12 PM
Trunk car 4th/6th order or ?? 98AckCL23 Enclosure Discussion & Design Construction Help 33 07-21-2009 11:24 AM
In order fatpat1080 Uncensored Off Topic 26 07-01-2009 11:17 AM
