fiberglassing my doors - Car Audio Classifieds!
Old 01-05-2010, 12:32 AM
30Hz
0/11 sssss6601
Feedback Score: 47 reviews
Default fiberglassing my doors
wasnt gonna put this on here but decided why not. this is my first ever time fiberglassing and doing sumthing like this. ive seen ppl do glassing but never helped just watch.
so dont laugh to bad but i think i did a pretty good job so far.
had to change it up was gonna do a 8" SS mid and redone it for dual 6.5" comps.
Old 01-05-2010, 12:37 AM
dak446's Avatar
0/11 sssss5914
Good start. MOAR PICS
indytrucks's Avatar
CACO Late Night Crew
0/11 sssss5387
Well?..... What truck is this for?
30Hz
0/11 sssss6601
used sum felt from jo anns fabrics to put over the MFD rings. sprayed it down with 3M super 90 to hold it down with.
mixed up resin to coat the felt and give it a hard shell to start to lay the fiberglass down. put 2 coats of resin and did the inside of the doors were felt was showing.
Old 01-05-2010, 12:38 AM
30Hz
0/11 sssss6601
this is for the black one im liking the door paneless yellow one
s10
Old 01-05-2010, 12:44 AM
30Hz
0/11 sssss6601
ok here i didnt have my cam for the fiberglassing, but its there under the bondo. 3 layers thick of 5 mil woven strips i cut from a big sheet.
here i was just test fitting the comps to see if there flat all around the mid and it was a bit off on the bottom right corner. i used more bondo raise it up flat.
here i spayed black primer on it for when i sand them down the low spots would really stick out.
Old 01-05-2010, 12:45 AM
30Hz
0/11 sssss6601
Originally Posted by wenn_du_weinst View Post
s10
yep 01 s10
Old 01-05-2010, 12:48 AM
0/11 ssssss530
looks good man i've seen worse first time fiberglass builds
Old 01-05-2010, 12:53 AM
30Hz
0/11 sssss6601
this is of course after sanding it the first time. them using filler putty to fill in all the low spots. this is after 3 times of sanding and refilling in the low spots
damn this part took sum time letting the putty dry resanding over and over. started out with 60 grit and went to 100 grit, finally sanded with 220 grit for the extra fine sanding.
Fiberglassing Q&A forceww Sound Deadening & Fabrication 121 03-31-2013 04:17 PM
Fiberglassing in FL mazda6i07 General Car Audio Discussion & Questions 9 08-20-2009 11:32 AM
help fiberglassing doors... canyouhearmatt General Car Audio Discussion & Questions 6 04-19-2009 10:19 PM
How to: Fiberglassing your sub box SPL Guru Tutorials & Quick References 11 08-05-2008 03:43 PM
