Enclosure Build: Local's 12" P3's - Car Audio Classifieds!
Old 01-31-2010, 11:52 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
Default Enclosure Build: Local's 12" P3's
Alright this enclosure will be for 94delsol (not from the audio forums) for his pair of 12's
Specs come to:
-1.875 cubes net per sub
-38hz tuning
-33.6875 sq inches of port area per sub
A look at the design:
And I didnt have a whole lot of time to be at the shop today so only got the majority of the pieces cut and the back panel mounted..
Rabbeted the edges of the side panels for easier/better carpeting later..
Side panel on (just clamped it down and will add screws tomorrow, I prefer doing this with those rabbeted edges)
Cutouts..
Attaching the first port pieces to the sides of the front baffles..
(In the last few pics I realized I forgot one of the screws holding the panels together)
Louder. Lower.
Team Tupperware
Old 01-31-2010, 11:53 PM
0/11 sssss8346
Center devider in
Port elbox inserts..
Primed
Painted
Paint drier
Corner insert in
Other side on
Primer
Painted
Drier
Louder. Lower.
Team Tupperware
Old 01-31-2010, 11:54 PM
0/11 sssss8346
Other 45 insert in..
Other 2 45's cut..
Port walls and front baffles getting mounted..
Smaller port pieces and last 45's in..
Louder. Lower.
Team Tupperware
Old 01-31-2010, 11:56 PM
0/11 sssss8346
Top went on and everything traced from the inside of the enclosure so that I can make accurate predrill holes..
Holes drilled..
Top on while I had some shok wire out for some reason..? I think I was just looking at it, lol
I got it all cleaned up and ready for carpet
A better view of the port opening..
It will be finished off in charcoal carpet
Louder. Lower.
Team Tupperware
Old 01-31-2010, 11:58 PM
looks good, still can't understand how you can work with mdf it bothers the hell out of me lmao
Old 01-31-2010, 11:59 PM
0/11 sssss6981
Looks nice man, god sanding a box makes it look so much better hahaha nice work as usuall
Old 02-01-2010, 12:01 AM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
got enough clamps? lol nice work man
what did you use for the edges for carpeting?
- CALI SOUNDS
- VERTEX AUDIO
0/11 sssss8346
Thanks. And I wear a mask now with the in the small space, it doesnt bother me at all with that on
Thanks, and yea it looks a lot nicer with the glue and paint gone.
Meh, ive got a decent amount lol. And yea, GetLikeMe's got it, I lower the table saw blade and use it for the rabbet cuts
Louder. Lower.
Team Tupperware
0/11 sssss6981
He uses his saw blade i think.
Old 02-02-2010, 02:47 AM
0/11 sssss8346
All finished up
Got the terminal holes cut..
Carpet time..
And...finished...
Mmhmm
Louder. Lower.
Team Tupperware
Enclosure Build: Sealed for 12" Pioneer~Saturn Build Logs 4 01-10-2011 09:25 PM
Enclosure Build: Local Buddy's 12" SSD Pioneer~Saturn Build Logs 7 09-21-2009 07:57 PM
Enclosure Build for single 15" Pioneer~Saturn Build Logs 3 08-09-2009 11:46 PM
Enclosure Build: 15" for Matt Pioneer~Saturn Build Logs 21 07-24-2009 01:52 AM
Enclosure Build For A Local's 3 15s twisted Build Logs 7 04-19-2009 12:54 PM
