Focal Door Pod Build - Car Audio Classifieds!
Old 03-04-2010, 04:47 PM
0/11 sssssss44
Default Focal Door Pod Build
Here's the door pod build for my Silverado. I forgot to take a lot of pics when I built the actual fiberglass pods, I got in "go time mode". Well onto the goods...
Cascade V-block sound deadener applied to outer and inner skins of the doors.
If you heat it up with a heat gun you can use a roller and a piece of cardboard to help it form to the door.
Old 03-04-2010, 05:02 PM
0/11 sssssss44
Here is a MDF ring that goes between the inner metal door skin and the plastic door panel. It provides a rigid mount for the fiberglass pod by connecting it to the actual door and improves mid bass response. The ring was made from two pieces of 3/4" MDF laminated together and then planed down to 1 1/8" so it fit perfect between the two panels. It was then coated in resin for waterproofing.
Old 03-04-2010, 05:06 PM
0/11 sssssss44
Foam seal attached on both sides to seal and eliminate vibrations...
Old 03-04-2010, 05:10 PM
0/11 sssssss44
Attached to the door with 8 10/32" bolts...
Old 03-04-2010, 05:14 PM
0/11 sssssss44
Here are the only pics I took of the rings...
Old 03-04-2010, 06:36 PM
0/11 sssssss44
Here are the pods after paint...
Silicone applied to the door panel to eliminate vibrations...
Mounted to the door panel through the midrange opening with bolts and the bolts that hold the MDF spacer ring in place also go through the plastic door panel and fiberglass pod so the entire assembly and all of the parts are rigid to achieve that sweet mid bass response...
Old 03-04-2010, 06:39 PM
Slappin F150's Avatar
0/11 sssssss73
That looks awesome.
Old 03-04-2010, 06:46 PM
0/11 sssssss44
Thanks!
Old 03-04-2010, 06:48 PM
luises14's Avatar
Loyal Member
0/11 sssss2531
Feedback Score: 30 reviews
very nice work
Old 03-04-2010, 06:49 PM
0/11 sssss1917
Those look real nice. You guys make it look easy but I'm worried about doing mine.
Focal Utopa 7w2 thisgsx Component & Coaxial Speakers 7 06-23-2012 06:13 AM
Focal KRX3 set, help me please?? Wheres The Butta General Car Audio Discussion & Questions 0 07-24-2009 09:36 AM
My door panel build DeadlySones Build Logs 5 07-15-2009 09:42 PM
Focal FP1.800 terrytee CACO Amp Internals 0 03-22-2009 03:51 PM
Focal natisfynest General Car Audio Discussion & Questions 5 02-13-2009 09:35 AM
