My Durango build - Car Audio Classifieds!
Old 05-01-2010, 09:27 PM
0/11 ssssss139
Default My Durango build
Nothing too crazy, its a 2000 Dodge Durango "Sport" to start with.
head unit:
Eclipse CD8445
sub stage:
18" Fi BTL, fully loaded, universal, D2
Digital Designs Z1
7ft^3 net with 6" aeros @ 34hz/40hz for comps/daily
Mids/Highs:
SoundStream TRC.6n's (two sets)
SoundStream RUB600.4
Electrical:
3 runs of 1/0
2) C&D 350mr's
130A stock alternator
300A Ohio Generator alt
Monster OFC wire from alts to under hood C&D, KLMX everywhere else.
here is the amp with the plexi cover the guy on CA made for me....
Old 05-01-2010, 09:34 PM
0/11 ssssss139
I got my new speaker wire for the mids ran yesterday, I got the RCA's all installed, remote wire ran, and made the bussbars for the rear batteries. Today I got the under hood bussbars made up, I just need to have my buddy weld the tabs so I can actually mount them to the batteries. they will sit just like they are in the pictures but about 1/4" higher. The extra material hanging over is what will be cut and used for the mounting tabs so don't worry about it being ugly LOL...
Old 05-01-2010, 09:52 PM
hifonicsviii's Avatar
Loyal Member
0/11 sssss1423
Nice man, why is the plexi bigger then the amp, is that for flush mounting or will it be screwed on teh amp itself
556 positive feedback from 506 users on Ebay!!!
Paypal verified ..207..since 2004
Bought from- - ShiZZZoN - pieper88 -
Sold to - super_duper - lilkman2202
Old 05-01-2010, 10:25 PM
0/11 ssssss513
looks good so far bro, i like the bussbar nodoubt..more pictures..
Old 05-01-2010, 10:28 PM
0/11 ssssss139
the plexi is 1/4" and is actually the exact same size as the amps mounting tabs because I am just planning to screw the plexi to the tabs and then flush mount it...
Also, I just realized I only need 3 terminals on the negative bussbar under the hood because I am only running positives to the back. I am going to have the runs from the front battery to the frame and then a couple from the frame to the engine block. Then of course the rear batteries to the frame (also three runs there). I know everyone likes the negative runs as well but I think with a full framed vehicle I will be OK, the cadillac was actually grounded to a pinch weld and it worked great for 2 years so...
Old 05-01-2010, 10:31 PM
0/11 sssss1208
Who made it?
Old 05-01-2010, 10:36 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
hey, do me a favor. when you get to the mids find out how deep of a mid you can fit. i'm looking into componets for my 02, so i wanna make sure i get something that will fit.
Proud Member of CAAA!
Old 05-01-2010, 10:43 PM
0/11 ssssss139
Already did the mids... the TRC.6n's didn't fit in the front at all, the hit the window guide. However, I actually took the plastic ring off of the stock speakers and used them as a spacer and then they fit perfectly, that is about 1/4" thick so you could fit roughly 2.25" mounting depth without any spacers.
The rears I thought fit fine until I rolled the windows down and they stopped with about 4" to go LOL... I am going to be doing the same thing I did up front for the rears. There is a good amount of space between the speaker and the door panel. Even after I put the 1/4" spacer up front there is a good 1/2"+ of clearance. I will be taking pictures when I do the others tomorrow so you can see what I mean if you don't get what I did.
Old 05-01-2010, 10:46 PM
RollerDJ's Avatar
Plays With Fire
0/11 ssss10067
well hellz bellz. i thought i hit the big time on that ride considering that my nissan had almost no room at all. i'll have to look for some more illustion lm-6's then. thanks for the imput!
Old 05-01-2010, 10:58 PM
0/11 ssssss139
just did a little pictorial for fun... also measured and the spacers are 3/8". Also that mounting depth was based on the TRC.6N's having a mounting depth of 2.6" and I know I only needed about 1/4" more clearance. I just used adhesive to mount the spacer ring to the factory deals and then screwed the speakers right into those rings. the got nice and TIGHT, no stripping or anything, that plastic is thick!
Box for Durango 12" Sub gem1n121 General Car Audio Discussion & Questions 0 03-17-2010 08:57 AM
Need Opinions On Durango Boomboy General Automotive Chat 13 03-04-2010 01:14 PM
How can build this lorenzofame General Car Audio Discussion & Questions 7 08-23-2009 01:15 PM
should he build it? korey_hofer Enclosure Discussion & Design Construction Help 20 07-25-2009 02:55 AM
durango box korey_hofer Enclosure Discussion & Design Construction Help 6 02-17-2009 10:24 PM
