old camry 2 15" omegas trunk build - Car Audio Classifieds!
Old 06-12-2010, 11:55 PM
Prohibited Sellers/Buyers
0/11 ssssss481
Default old camry 2 15" omegas trunk build
Hopefully this setup will stay in for the rest of the year. Ive been switching it up way too much and finally found some subs I might like. It will be nice to actually finish a build completely, that is the plan.
2x d2 omegas
1x ap3k (need more power)
1x 10" aeroport
Mint old school eclipse 5444
3x Lightning audio 250w 2 channels
2x Eminence alpha 6.5s
2x Vifa Tweets
Blue top/ C&D 370.
150A alt
Eventually, 200A at and a few more batts, 5-6k, New struts
I need to write NOT above the DD on the dustcaps or get new ones to avoid having to explain the dustcaps to everyone.
the rear portion of the previous box will be re used:
This is the only pic i have right now of the opening which needs to be expanded a little width wise with a sawzall and grinder
This will be facing in the cabin like a blow through. The pipe in the middle is a coupler for the 10" aero
Old 06-13-2010, 12:00 AM
0/11 ssssss481
Eventually ill put a clean window but this is the acess hole to do stuff in the box like attach the boxes and put the port in
Old 06-13-2010, 12:02 AM
0/11 ssssss481
tomorrow I will add some external bracing and double some panels up and maybe even hear it depending on how the resin cures. The resin was mostly just to hold it together better on the angles of the front cause I didnt match them the best. Then i decided to give it a coat even though some say its not worth it.
Old 06-13-2010, 12:48 AM
newarkbeast973's Avatar
0/11 sssss7810
where the hell is the amps going? lol
New build coming soon!!
Old 06-13-2010, 12:52 AM
aturcotte127317's Avatar
Veteran Member
0/11 sssss3613
This looks very interesting!!! Tuned in!!
147.5 sealed on dash
149.0 in kick
and climbing
2 12" 2010 Type Rs
or
1 15" DD 9915
Audison VRX 1.500
or
Sundown SAZ1500D
Crescendo 1000C4
SHOK wire
Old 06-13-2010, 01:00 AM
0/11 ssssss481
I run the two mids amps under pass. seat tweet amp under driver seat and the sub amp will go behind the seat in front of the box
Old 06-13-2010, 07:29 AM
0/11 ssssss481
what should i tune these to? 3.75ft each
Old 06-13-2010, 10:39 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
lower 30s
92 Ranger Walkthrough
(Under Construction)
Old 06-13-2010, 05:34 PM
0/11 ssssss481
Update.
It went pretty good except for I kept getting rained on and had to move shit into my 1 car garage.
QUEstion. do you guys think it will hurt the subs to put them in the box without the resin FULLY cured. like it still smells, because the resin will eat through plastic and styrofoam cups pretty quick. Do you think it would hurt the glue joints?
This will go between the box and seat brace.
Added bracing
More bracing
Old 06-13-2010, 05:42 PM
0/11 ssssss481
Casper129's trunk build casper129 Member Rides & System Pictures 23 02-26-2012 07:28 PM
How to build a box INSIDE the trunk? westman995 Enclosure Discussion & Design Construction Help 12 06-24-2010 06:48 PM
4th order Possible 6th Trunk Build pics amartin_72 Build Logs 25 05-25-2010 02:58 PM
21" Death penalty Trunk build- 5 seperate boxes amartin_72 Build Logs 71 03-14-2010 03:25 PM
Camry Build. ahillaudio Build Logs 10 12-29-2008 08:01 AM
