CRX door panel build SPL Burp GUYS BEWARE - Car Audio Classifieds!
Old 06-25-2010, 05:52 PM
0/11 ssssss339
Default CRX door panel build SPL Burp GUYS BEWARE
some glass added to the back of the door panel to strengthen it (flimsy plastic)
what you know bout using Weed Killer to glass doors with?
Old 06-25-2010, 05:55 PM
0/11 ssssss339
after 1st layer of mat (thick mat too not flimsy bondo crap)
side view to show depth
after 2nd layer of glass (not sanded yet) look at it on the car
Old 06-25-2010, 07:57 PM
armymp90099's Avatar
Boomin' Bull
0/11 ssssss416
looks good so far. Can you please explain the weed killer thing? Im lost.
Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Live, I will kill you. If I die, you are forgiven." Such is the Rule of Honor.
Old 06-25-2010, 07:59 PM
0/11 sssss2148
Feedback Score: 26 reviews
Should be rather loud
Old 06-25-2010, 08:00 PM
0/11 ssssss339
i'm from fl of course it has to be loud.
Old 06-25-2010, 08:03 PM
KINGDELL91's Avatar
0/11 ssssss639
i have that same weed killer now i have a use for it! well how did u use it lol?
Old 06-25-2010, 08:10 PM
0/11 ssssss339
to explain there is a local boat shop that sells poly resin for really cheap and they didnt specify that i needed to bring my own container. so thats what they had around the shop to use to hold a gallon. (note 1st gallon they gave me was in a gallon can of resin *all used before he filled it for me*)
So it isnt weed killer and its actually marine grade poly resin. the green resin on the inside of the door panel is US Composites. NEVER USE BONDO BRAND RESIN. that junk is like jelly compared to this real grade resin..
Old 06-27-2010, 08:43 PM
0/11 ssssss339
got to doing the passenger side yesterday...and some body filler (evercoat z-grip) on the driver's side while the resin dried. Also brought out the dremel i bought 2 years ago to clear out the holes for the mids and tweeter. not too bad of placement and fit if you ask me. ESPECIALLY FOR MY FIRST SET OF DOORS.
Old 06-27-2010, 10:51 PM
0/11 sssss3842
everything looks good but i see 2 things you might want to work on next time.
1) try stretching that fleece better. i seen a couple wrinkles that coulda been stretched out with some more work.
2) trim the excess material before applying resin. Will help in the long run.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 06-27-2010, 10:55 PM
0/11 ssssss339
thanks but the wrinkles were as little as possible with the shape of the panel and what i wanted to put on it...plus i know a thing or 2 about body repair so these should be no problem with the filler.
Jeep Door Panel Build EpicenterDesigns Build Logs 93 06-12-2010 04:59 PM
Focal Door Pod Build oline897 Build Logs 32 03-11-2010 09:18 PM
Door Panel Design Help strpperpolef150 General Car Audio Discussion & Questions 9 02-17-2010 10:27 PM
My door panel build DeadlySones Build Logs 5 07-15-2009 09:42 PM
Upcoming completion of my build whatcha guys think? nismos14 General Car Audio Discussion & Questions 8 09-09-2008 01:45 PM
