'05 Avalance RD/AQ Build - Car Audio Classifieds!
Old 06-25-2010, 10:49 PM
Prohibited Sellers/Buyers
0/11 ssssss786
Default '05 Avalance RD/AQ Build
- '05 Avalanche
- (2) RD Alpha Max 15s with HW softparts
- (1) Audioque 2200d
- Box is a blowthough, thorough the midgate. Tuned to 32hz, 45s in corners, and resined. It's being build by a local world record holder box builder
- All KNU wiring. 30ft of the new KCA wire.
- Sprinter 134ah battery
Later on he'll probably get another AQ2200 and strap 'em. Should be loud! Everything is basically in the mail, so more pics as it happens.
Old 06-26-2010, 02:40 PM
0/11 ssssss786
Will add double baffle if it flexes. And trim pieces with foam for that gap..
Old 06-26-2010, 02:43 PM
fiji24's Avatar
0/11 sssss1826
Nice build!
2003 Chevy Trailblazer
Subs- 4 Fi Q 12's
Amps- Sundown 3500D & Rockford Fosgate Power T400-4
Mids- 2 Peerless 6 1/2's Nomex Cone HDS Woofer
Highs- 2 Bohlender Graebener Neo8-PDR Planar Transducers
Headunit- Alpine CDA-9835(ACTIVE)
Old 06-27-2010, 09:07 PM
0/11 ssssss786
One layer of resin on
Old 06-27-2010, 09:11 PM
kingmade08's Avatar
Awaiting Confirmation
0/11 sssss1067
i built my avalanche box,it turned out awesome...no longer have the avy tho lol,there hard to get loud in
TEAM SUNDOWN AUDIO
Old 06-29-2010, 08:11 PM
0/11 ssssssss6
what did u do to stop it from leaking?
Old 07-01-2010, 12:04 AM
kingmade08's Avatar
0/11 sssss1067
at first it didnt leake then early spring it started and i mounted 2 1 inch diameter round pieces of wood that held the last piece of the toneau in place from the inside of the box sticking strait up. prlem with an avalanche blowthru is theres not much resistance anywhere making lows hard to acomplish, and dbs are guna be on the low side i did like 138 with a rd alpha on 1200rms
TEAM SUNDOWN AUDIO
CLNFREAK'S build... rebuild.... build... CLNFREAK Build Logs 43 06-26-2012 06:25 PM
Can someone help me build a sub? hornedfrog1985 General Car Audio Discussion & Questions 10 04-12-2010 08:48 PM
97' s10 LS Build Log RidnClean Build Logs 9 02-27-2010 06:39 PM
So you are going to build a box? here's what you'll need iamsonic Tutorials & Quick References 0 09-18-2009 06:28 PM
