Build&Restore of 92 ford bronco. - Car Audio Classifieds!
Old 08-23-2010, 11:02 AM
Prohibited Sellers/Buyers
0/11 sssss6709
Feedback Score: 17 reviews
Default Build&Restore of 92 ford bronco.
Well guy's this will be going through couple step's in this build. This build is on a 92 ford bronco also will be helping em rebuild it as you can see she need's some help but damn is it fun to drive. But anyway's onto the build here's what the build consist's of.
.Equipment.
Wiring: Stinger 1/0awg , BIG 3 wire might be diffrent depending on what he want's to do.
Deck: Cheap Jvc for now.
Frontstage: some old skool kicker seperates
Rear stage: 5x7 eclipse component's
Subwoofer: Still in the works
Sub amp: still in the works.
The fronstage/rear stage will be upgraded though customer want's to do either one nice 4ch for both or either two 2ch on each i will be making a beauty panel right above box.
Re did all the wiring the customer had wiring nightmare on his hand's open wires everywhere , way to many wires ran that were not needed. wish i took pics of the wiring nightmare but i was to busy ripping out wires labeling everything. also everything in the install will be tied down real good because the customer also does alot of off-roading.
Here is a shot of the customer's vechile.
Another side shot of the vechile.
Please keep in mind the customer actually is rebuilding/restoring the truck with his uncle and also doing alot of the work himself. but he is making sure to do it all right braising the metal , filler right , metal add in's.
Started to pull up the carpet and found wiring nightmare.
Plan on doing alot more work to this truck. im working with em on the build because it's his first build and he tight on cash.
05 Ford F-250 Harley Davidson Edition Build Ami Creations General Car Audio Discussion & Questions 85 12-29-2010 09:06 PM
2004 Ford Explorer build - pure pressure audio anj46907 Build Logs 19 09-26-2009 12:24 AM
never seen a bronco like this bones22 Off Topic Chat 10 07-03-2009 05:11 PM
Box build Ford Explorer on1wheel01 Build Logs 3 04-08-2009 01:09 AM
99 Ford Explorer SQL Build funkycasey Build Logs 14 11-25-2008 06:52 PM
