2008 Altima's trunk - Car Audio Classifieds!
Old 09-13-2010, 10:44 AM
0/11 ssssss468
Default 2008 Altima's trunk
So my ideal trunk is to have as much space as possible, easy access to spare tire and being able to fold rear seats down (both parts of it) and carry long/oversized stuff that doesn’t fit in the trunk alone.
Having it look good woun't hurt either - plexiglass, led strips, fans if needed.....
Fiberglass sealed enclosure work for 12'' sub in the corner will soon begin but meanwhile I did this rack basically to practice and see for myself what I’ll need to do once I have all materials needed (another amp and sub lol).
I never did this before, figured having some practice and experience with it wouldn’t hurt before going all out.
For now a piece of plywood on top and some carpet and it’s good to go. Till I re-do it LOL.
btw – all those PA amps have their own harness with 2sets of wires for led strips or cooling fans if needed, I’ll make sure to use them for my final amp rack
Any ideas, feedback, criticism welcomed.
PA500.4's (100Wx4) front channels are pushing Polk Momo's (MMC6500) woofer in the front and rear channels (set to LPF) pushing Momo 6x9 (MMC690) in the rear.
PA200.4's front channels are pushing Momo's (MMC6500) tweeters.
This way I got bi-amp'ed comps in the front and 6x9s in the rear playing only bass and lower midrange.
Will add mono amp to feed my sub.... soon... Will possible get rid of 6x9s then (together with PA200.4) we'll see....
Just so happened i got a chance to carry queen size metal bedframe the very next day
Old 09-13-2010, 02:44 PM
0/11 ssssss530
nice job on that amp rack came out good so far
98 ford explorer
HU: power acoustik ptid-8001n
mids and highs: RE FR 6x8's
Sub Amp: pheonix gold v752
Sub: e8
free bass tests
Old 09-13-2010, 02:51 PM
newarkbeast973's Avatar
1/11 sssss7810
are you going to cover it?
New build coming soon!!
Old 09-13-2010, 02:54 PM
0/11 ssssss242
nice. I have an 08 as well, I might have to try something like this.
Old 09-13-2010, 03:30 PM
0/11 ssssss468
Piece of plywood on top and matching carpet on top of plywood.
As i said before - this is my first rack before i get my sub in fiberglass sealed enclosure. Depending on how that will tirn out i'll re-do this amp rack. Plexiglass, led strips, fans if needed... For now i just wanted to clean up my trunk, get some space back and get some experience with building these racks.
Based on this one i can already tell that my "good" rack will:
- be build using 1x4 as opposed to 2x4 - really don't need those beams to be that wide, 1x4 will do just fine - more trunk space, less weight, same result.
- have small square 1/4'' plywood pieces under 4 corners of both amps to raise up amps 1/4'' of the floor so there's some air between amps and floor.
- about 3/4'' plywood pieces to go under momo x-over to bring them up top closer to future plaxiglass that will be showing my equipment for that "that looks good" effect
I'm basically looking for as many advices as i can possibly get since that's my first amp rack but general idea will stay the same.
Old 09-13-2010, 03:47 PM
0/11 ssssss242
Hey what kind of Polk audio components are those? I'm looking for some for my altima.
Any good or bad things to say about them??
Old 09-13-2010, 03:51 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
You end up needing some fans hit me up i got a few extras
Old 09-13-2010, 04:22 PM
0/11 ssssss468
David, shoot me pm with specs/info. Don't know if i need them yet but would like to be prepared in case i do.
I got MMC6500 - Polk Audio MOMO comps. GREAT comps!!
Good:
very punchy AND bass'y at the same time, no compromise.
bi-amp'able
Bad:
tweets are too bright for my liking. When not in bi-amped mode they are just to loud compared to mids. Ability to bi-amp them saves the day by lowering those highs thus bringin up mids. With that said i'm sure it's not fault thou - i placed tweets right next to the ears (side mirror covers) and away from woofers. If i intalled them in kick panels or door panel itself i'm sure they woun't apper to be as bright.
Overall i'd get these same comps for any car, very powerfull and clear at the same time. Techno kick drums never sounded better
4 door trunk car - cant use trunk ... brian84corvette Enclosure Discussion & Design Construction Help 23 10-13-2010 08:24 PM
Trunk Enclosure for a 2008 Dodge Avenger MopaRBumpiN Enclosure Discussion & Design Construction Help 15 07-11-2010 08:30 PM
Just Showin' Off for Toys for Tots 2008 ~ Huntsville AL ~ 11-15-2008 CACO's Car Show Bot Car Show Feeds 0 10-27-2008 02:00 AM
Motor Sports 2008 ~ Tacoma WA ~ 11-07-2008 CACO's Car Show Bot Car Show Feeds 0 10-26-2008 02:00 AM
USACi Sanctioned Event - In The Trunk ~ BEAUMONT TX ~ 10-04-2008 Patrick Simmons Car Show Feeds 0 09-29-2008 02:05 AM
