Box build for Fi Bl 12 - Car Audio Classifieds!
Old 09-22-2011, 07:55 PM
0/11 sssss1046
Default Box build for Fi Bl 12
This is just a quick box i made this afternoon to fit behind the seats of a mid 90's single cab Chevy 1500. The box is 2.0 cubes with 25 sq in of port tuned to 32 hz. It will be powered with about 750 watts, so we'll see if he needs a bigger amp or not, but this should be a pretty efficient box for his needs. "Terminals" are 2 5/16" bolts through the wood. Needed to have the spacer ring to get more mounting depth for the sub to fit. Here's a couple of pictures of it finished.
Box Build: 15" SMD Box.. GetLikeMe Build Logs 19 09-11-2011 03:43 PM
2.25 @ 38 Box Build BuckyBoy Build Logs 1 02-06-2011 02:04 PM
deepsilencer's new box build video designed by james(A.I),build by 99s10walled deepsilencer Car Audio Videos 1 08-30-2010 02:43 AM
So you are going to build a box? here's what you'll need iamsonic Tutorials & Quick References 0 09-18-2009 07:28 PM
