Alpine MRX-M100 - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 06-06-2012, 02:46 PM
dagodpere's Avatar
0/11 ssssss167
Default Alpine MRX-M100
Amp Name:
MRX-M100 by Alpine
Specs:
General
  • Power Requirements: 14.4V DC (11V to 16V)
  • Input Sensitivity (RCA Input): 0.2 - 4.0V (Rated power into 4I?)
  • Input Sensitivity (Speaker Level Input): 0.5 - 10V (Rated power into 4I?)
  • Input Impedance: > 10kI?
  • Frequency Response (+0, -3dB: 1W into 4 Ohms) for Subwoofer: 5-400Hz
  • Frequency Response (+0, -1dB: 1W into 4 Ohms) for Subwoofer: 10-300Hz
  • THD+N (10W into 4 Ohms) for Subwoofer: <0.004% (10W into 4I?)
  • THD+N (Rated Power into 4 Ohms) for Subwoofer: <0.04%
  • Damping Factor for Subwoofer: >1000 (10W into 4 ohms at 100Hz)
  • Signal to Noise (Rated Power into 4 Ohms) for Subwoofer: 117dB (IHF A weighted + AES17, Rated Power into 4 ohms)
  • Preamp Output: 4V (Max.)
  • Remote Level: 0 to -20dB (RUX-KNOB required)
  • Weight: 3.8kg
Sound Tuning
  • Crossover Frequency (LPF): 50-400Hz (-12dB/oct.)
  • EQ (Equalizer): Bass EQ (fc=50Hz), 0 to +12dB
  • Subsonic Filter: 5-30Hz (-24dB/oct.)
RMS Power Ratings
  • Per channel into 4 Ohms: 600W x 1 (@14.4V Ƈ% THD+N, 20Hz - 200Hz)
  • Per channel into 2 Ohms: 1000W x 1 (@14.4V Ƈ% THD+N, 20Hz - 200Hz)
Max Power Output Ratings
  • Max Power: 1900W
Dimensions
  • Foot Print (WxHxD) mm: 340mm x 58mm x 230mm
  • Foot Print (WxHxD) in: 13-3/8'' x 2-1/4'' x 9''
  • Heat Sink (WxHxD) mm: 280mm x 58mm x 230mm
  • Heat Sink (WxHxD) in: 11'' x 2-1/4'' x 9''
Pictures (required):
Reference/Credit
Self
Old 06-07-2012, 03:41 AM
0/11 sssssss54
Thanks, I've been interested in this amps internals. Do you remember the voltage of the caps.
Old 06-07-2012, 10:42 AM
dagodpere's Avatar
0/11 ssssss167
No, sorry I don't.
Old 08-20-2012, 12:53 PM
Contributor
0/11 ssssss527
Alpine and their wacky shell style transformers and toroids...
Alpine mrx-v60 Frankie CACO Birthsheet Archive 1 03-30-2012 03:21 AM
Phoenix gold m100 Galant_916 CACO Amp Internals 0 08-15-2011 04:31 PM
[FOUND] WTB: PG M25, M50, or M100 Pillow Wanting to Buy (WTB) 1 04-18-2010 09:52 PM
