Rockford Fosgate T20001BD - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 07-30-2012, 01:05 AM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
Default Rockford Fosgate T20001BD
Amp Name:
RF T20001bd
Specs:
2000 Watt RMS Class BD Amplifier
RMS Power Ratings:
750 watts RMS x 1 at 4 ohms
1,500 watts RMS x 1 at 2 ohms
2,000 watts RMS x 1 at 1 ohm
Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control
MEHSA- High Performance Thermal management design for bigger power with more consistent thermal stabiity
MOSFET power supplies and outputs
TOPAZ - Circuit for eliminating engine noise
NOMAD - Advanced short circuti and power protection
MasterSync - allows one amplifier to manipulate another amplifier's gain, EQ, Infrasonic and crossover controls
PowerSync - Allows bd series amplifiers to be "strapped" together to create one massive power combination
variable low-pass filter (32-250 Hz, 24 dB/octave)
Infrasonic filter: 12dB/oct Butterworth alignment protects the amp from unwanted ulta-low frequency information, increasing the usable power output and reliability
RCA Preamp Outputs
Phase switch: 0 - 180 degrees
Cast aluminium heatsinks - allows more power into a smaller heatsink by allowing engineers to localize heat in specific areas
3-Stage Variable forced convection - heatsink design that keeps the amp's internal components cool
1/0 AWG power and ground connections with internal ANL fusing
Dimensions: 23" L x 12.8" W x 2.66" H
Pictures (required):
Reference/Credit :
Q.W.
rockford fosgate t20001bd ray60218 Craigslist Deals 3 05-25-2012 02:13 AM
rockford fosgate t20001bd gredysra Broken & Non-working equipment 7 04-09-2012 03:57 PM
Rockford Fosgate t20001bd jrod1050 Mono Amplifiers 11 03-26-2011 12:12 AM
Rockford Fosgate T20001BD 46panel Mono Amplifiers 4 10-22-2009 12:25 AM
