Audiobahn 2200HCT - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 03-05-2013, 12:07 PM
0/11 ssssssss7
Default Audiobahn 2200HCT
Amp Name:
Audiobahn 2200HCT
Specs:
  • RMS Power Rating:
    • 200 watts x 2 chan. @ 4 ohms
    • 400 watts x 2 chan. @ 2 ohms
    • 800 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 400 watts x 1 chan. @ 4 ohms
      • 800 watts x 1 chan. @ 2 ohms
      • 1600 watts x 1 chan. @ 1 ohm
  • Max Power Output: 3200 watts @ 1 ohm
  • Wired Remote Bass Level Control Included with Blue Illuminated Knobs
    • Also illuminates red to indicate when amplifier is clipping
  • High-Current, Non-Regulated Power Supply
  • Preamp Outputs
  • Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
  • Thermal Regulated, Air Induction Dual Cooling Fans
  • Double Sided PCB (Circuit Board)
  • High Gloss Chrome Plated Finish
  • Unique, Clean Chrome Fire/Flame Design
  • Blue Illuminated VU Meters Indicating Output Response
  • Clear Power and Speaker Connectors
  • Variable Bass Boost: 0-18dB @ 40-100Hz
  • Variable Low-Pass Crossover: 40-120Hz
  • Variable High-Pass Crossover: 50-750Hz
  • Variable Subsonic Filter: 20-50Hz
  • Signal-to-Noise Ratio: 100dB
  • Frequency Response: 10Hz-40kHz
  • THD: 0.05%
  • Channel Separation: 50dB
  • Input Sensitivity: 200mV - 8V
  • 1/0- or 2-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
  • Dimensions: 23" L x 11-15/16" W x 2-1/2" H
Pictures (required):
Old 03-05-2013, 01:37 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
These actually made decent power. But inmy experiance ran hot since you had to run it at .5 to make any power. The high current design was nice cause you could loud it down but it was terribly ineffecient. Notice it has 16 power supply fets and 24 output fets to handle the current these things consume!
Old 03-05-2013, 02:23 PM
0/11 ssssssss7
Same amp I have been wailing on for the last 6+ years bridged @ 1 ohm. Loved the fact that it came with a gain control which incorporated a clipping light. Compared to other amp internals I have seen of similar power outputs, there is lots of room inside this. Lots of space for air to circulate through via the dual fans, never had an issue with it going into any kind of protection mode.
Old 03-05-2013, 02:30 PM
skinnyg's Avatar
0/11 ssssss828
is this the flame model? I had both, the first gold I had caught on fire, my fault, 4 12s in an ext cab s10 it split the seal between the glass and sheet metal and water leaked in and it caught on fire. They actually replaced it under warranty (back when audiobahn was a good company for about 2 years) and sent me the new chrome flame model and I sold it to my dumbass buddy who managed to blow it up like everything. But these things made power!
Old 03-05-2013, 02:34 PM
0/11 ssssssss7
Yup, this is is aflame!
My most recent set-up before I rebuilt my box.
WTB Audiobahn Immortal Motor or Blown 15" Audiobahn Immortal Sub Rayo187 Wanting to Buy (WTB) 219 03-24-2015 09:35 PM
Audiobahn 1800dt KEVGNAR Broken & Non-working equipment 4 07-01-2012 02:24 PM
Audiobahn 12? Jordd (PSI Car Audio) 3 05-07-2012 10:44 PM
audiobahn sub Austin175 General Car Audio Discussion & Questions 6 06-24-2010 02:10 AM
death to the audiobahn audiobahnfan General Car Audio Discussion & Questions 10 04-03-2010 03:17 PM
