US Amps Xterminator XT4000D - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 10-23-2013, 10:46 PM
OldsSafari's Avatar
0/11 sssssss29
Default US Amps Xterminator XT4000D
Amp Name:
Specs:
  • Dynamic Power: 4000W
  • RMS Power (1 Ohm): 1500W x 1
  • RMS Power (2 Ohm): 450W x 1
  • RMS Power (4 Ohm): 200W x 1
  • Signal to noise ratio: 80dB
  • Frequency Response: 20Hz to 500Hz
  • Low level input sensitivity: 200mV to 6VContinuously variable low-pass crossover
  • Base EQ control at 45Hz: 0 to 12dB
  • Line output with low-pass crossover
  • Platinum-plated connectors
  • Dimensions (inches): 13.8 (L) x 2.5 (H) x 8.75 (W)
  • signal to noise ratio: 80db
  • frequency response: 20hz to 500hz
  • continuously variable low-pass crossover
  • bass eq control @ 45hz: 0 to 12db
  • line output with low-pass crossover
  • platinum-plated connectors
Beasty little amp, been running it for 2 years on 4 10s and later just 2 10s. Definitely underrated, at 2 ohm I clamped it at a peak of around 900w on music.
Pictures (required):
Reference/Credit :Personal Stash
Resident Geeky Grease Monkey...
Instagram
@nightcrusin24 #wagonwagoff #becauselandyacht
us amps xt4000d MR. YOGI General Car Audio Discussion & Questions 5 03-11-2013 03:44 PM
US Amps XT4000D xsilentjihadx Car Audio Trader (WTT) 3 01-14-2012 11:22 PM
US Amps XT4000D xsilentjihadx Mono Amplifiers 0 01-12-2012 08:58 PM
US Amps Xterminator XT4000D timwebb General Car Audio Discussion & Questions 6 12-01-2011 07:34 AM
U.S. Amps Xterminator XT4000D Parker G Mono Amplifiers 14 07-06-2010 08:55 PM
