Precision Power Inc. Sedona PPI S2000.1D - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 03-09-2014, 08:13 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
Feedback Score: 22 reviews
Default Precision Power Inc. Sedona PPI S2000.1D
Amp Name:
Precision Power Sedona Series
PPI S2000.1D
Specs:
4 ohms: 750 watts x 1 chan.
2 ohms: 1300 watts x 1 chan.
1 ohms: 2000 watts x 1 chan.
Pictures (required):
Reference/Credit :
Just bought one. Will have clamp numbers shortly
Current 09 BMW 335xi: SQ build with Sundown and IA in progress
Retired '99 Jimmy: Highest TL 155.1 w/ 2 self made 12s and AQ3500.1
The Following User Says Thank You to csu87 For This Useful Post:
djscrubb (03-09-2014)
Old 04-16-2014, 12:20 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
Clamp Numbers
45hz burp
Gain set right at clipping (very very slight clip in oscope reading)
46.5 Volts
25.5 Amps
Input Voltage 13.5
1186watts @ 1.8 ohm @ 13.5 volts.
Rated at 1300watts @ 2 ohm @ 14.4 volts
Old 04-16-2014, 01:08 PM
0/11 sssss2011
Feedback Score: 61 reviews
not bad, based on this it should do very close to if not right on rated. good to hear for me b/c I use this amp.
Old 04-16-2014, 01:12 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
Yeah I had no issues with it and ran it at .5ohm daily
Old 04-16-2014, 01:14 PM
0/11 sssss2011
it does say in the manual that these will do something like 2300 or 2500 at .5Ω
Old 07-16-2014, 06:10 PM
0/11 sssssss27
What kind of electrical? Did you ever clamp efficiency when you were at .5 ohm? I am considering running 2 of these each at .66 (singer 200 amp and a d3400 up front) I know I need to add some batteries in the back I'm just not sure how many
Did the amp ever get hot or protect at .5?
Old 07-16-2014, 06:22 PM
csu87's Avatar
Louder then him^
0/11 sssss2525
2 kinetic 600s and my stock 90ah battery and stock alt. never clamped efficiency, never got hot or protected.
Precision Power S2000.1D - opinions? grimreper912003 General Car Audio Discussion & Questions 9 01-01-2014 08:25 PM
ppi s2000.1d amp... joemon General Car Audio Discussion & Questions 28 09-03-2013 12:40 AM
New exhaust 4 my S2000 kreapin Member Rides & System Pictures 26 02-20-2012 12:44 AM
Cerwin Vega Stroker Pro s2000.1 TaylorFade Mono Amplifiers 14 12-07-2011 10:16 AM
00' Civic Si (S2000 motor) Memphistahoe02 Miscellaneous Build Logs 46 10-31-2010 11:31 PM
