Ampere Audio AA-5000.1D - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 04-17-2014, 04:58 PM
So Low's Avatar
0/11 sssss1258
Default Ampere Audio AA-5000.1D
AA-5000.1D
Specs:
Number of Channels:
1
Power 14.4 VDC - 1 ohm:
5100W RMS
Power 14.4 VDC - 2 ohm:
2800W RMS
Power 14.4 VDC - 4 ohm:
1000W RMS
Power 18 VDC - 1 ohm:
6600W RMS
Power 18 VDC - 2 ohm:
3300W RMS
Bridged Power 14.4 VDC - 2 ohm:
8800W RMS
Bridged Power 18 VDC - 2 ohm:
10800W RMS
Input Sensitivity:
6V ~ 0.2V
Signal to Noise Ratio:
90dB
Frequency Response:
10Hz ~ 350Hz
Crossover:
24dB / Octave
Subsonic Filter:
10Hz ~ 60Hz
LPF (Low Pass Filter):
30Hz ~ 200Hz
Bass Boost @ 45Hz:
0 ~ 12dB
Phase Shift Control:
0 ~ 180 degree
Working Voltage:
10V ~ 18V
Efficiency:
86%
Recommended Fusing:
500A (external type fuse)
Dimensions:
246(W) x 80(H) x 640(L) mm
Pictures (required):
Reference/Credit :
Xplicit Audio Website
Old 11-12-2014, 09:27 PM
BigBoi's Avatar
0/11 ssssss117
nothing yet?
I advertised outside links. They were removed.
Old 11-12-2014, 09:28 PM
Andrew2944r's Avatar
0/11 sssss1226
The Following 4 Users Say Thank You to Andrew2944r For This Useful Post:
BigBoi (11-12-2014), Goldtaz1 (12-05-2014), Haelmuscle (12-16-2014), IS300IAdeathRow (12-15-2014)
Old 12-15-2014, 05:45 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
^^^^^^^awesomeness!!!
2013 Toyota Highlander
Build to come.....
Ampere Audio 5000.1D chevyboi-79 General Car Audio Discussion & Questions 7 04-17-2014 04:59 PM
Ampere Audio 3800.1 Andrew2944r Mono Amplifiers 22 12-18-2013 12:31 PM
Ampere Audio AA-15 D4 (Brand New) PHATBOi 15" Subwoofers 7 12-10-2013 10:07 PM
1997 Cadillac Seville-Sundown, Ampere Audio, PRV Audio nicholasmccabe Build Logs 0 11-05-2013 03:41 PM
