Orion XTR2200.1d - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 05-04-2014, 09:55 PM
0/11 sssssss72
Default Orion XTR2200.1d
Amp Name:
Orion XTR2200.1d
Specs:
RMS Power
@ 4 ohms 950 watts x 1 channels
@ 2 ohms 1700 watts x 1 channels
@ 1 ohm 2200 watts x 1 channels
200 Amp External Fuse
0.5 Ohm Stable
Pictures (required):
Reference/Credit :
You can get the XTR3700 online for $599 brand new, now bad for 4000+ watts!!
PASMAG Review of its big brother, the Orion XTR3700.1d: PASMAG | PERFORMANCE AUTO AND SOUND - Orion XTR3700.1D Amplifier
From Article: "Looking inside the XTR3700.1D reveals a well made product, with a clean, organized layout. Surface mount parts are used extensively in the front end, and Orion’s proprietary PRS power supply incorporates six individual toroids, one for each pair of high current MOSFET power supply devices. For energy storage, the power supply section employs ten 3300µF high temperature capacitors and the secondary gets its energy reserves from a bank of eight 820µF 200V caps. From the heavy copper traces on the double-sided PCB to the TO-247 case size transistors, everything inside the amp looks like it was designed to handle a ton of current with good reliability."
Manufacturers Rated Power | Power @ 12.6v | Power @ 14.4v
4 Ohms 1500 | 1310 | 1703
2 Ohms 2500 | 2205 | 2857
1 Ohms 3700 | 3192 | 4090
Max Amp Draw: 413 Amps
Efficiency @ 2ohms: 79%
External Fuse Rating: 350 Amps"
I would definately say that this amp is similarly underrated. It is one clean & smooth subwoofer amp.
WTB power plugs for Orion Xtreme 800 and Orion Cobalt 465 mizatt32 Wanting to Buy (WTB) 2 08-23-2012 04:05 PM
Orion 12" and Orion D-5000 amp (NW FL) BlueLude Craigslist Deals 0 02-08-2012 09:41 AM
Orion amp Manual NEEDED.. look inside Orion people 1dman General Car Audio Discussion & Questions 18 03-06-2011 10:12 PM
FS: Orion XTR 10" 4Ohm Subwoofer with Orion Box! Pillow 10" Subwoofers 5 03-07-2010 04:36 PM
