Kicker ZX300.1 - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > CACO Amp Internals
CACO Amp Internals Post amp internal pictures here. Replies are disabled.
Old 07-18-2010, 09:36 PM
FAUEE's Avatar
0/11 sssss1081
Default Kicker ZX300.1
Amp Name:
Kicker ZX300.1
Specs:
ZX Series Class AB Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 150 watts x 1 chan.
2 ohms: 300 watts x 1 chan.
MOSFET power supply
LED power and protection indicators
Optional bass remote Kicker 10ZXRC sold separately
Tuned Bass EQ (0-12 dB bass boost at 40 Hz)
Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
Optional vinyl skins for personalizing heat sinks available
Eliminates unwanted noise in a system
Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
Bridgeable operation
Speaker-level inputs compatible (switchable) through RCA connection
Preamp RCA outputs
Automatic turn on modes: remote, DC offset, or signal sense
Thermal, voltage, and short circuit protection circuitry
Fixed low-pass filter (80 Hz, 24 dB/octave)
Subsonic Filter (24 dB at 25 Hz)
CEA-2006 compliant amplifier
Frequency response: 25-20,000 Hz
Dimensions: 13-1/2"L x 9-5/8"W x 2-1/8"H
Pictures (required):
Reference/Credit :
Took these at work. Sorry for the blurriness, buddy at work hasn't got a steady hand with the cameraphone.
kicker l7 bikerdc17 Car Audio Trader (WTT) 2 03-29-2010 02:46 PM
box for 4 kicker 12s gbo559 Enclosure Discussion & Design Construction Help 11 01-23-2010 03:19 PM
[SOLD] WTT: Kicker 750.1 for Kicker 4ch FASTIMES Car Audio Trader (WTT) 1 02-02-2009 06:15 AM
