SMD DD-1 this is my review - Car Audio Classifieds!
Old 09-29-2011, 04:14 PM
Blazed SS's Avatar
0/11 ssssss184
Default SMD DD-1 this is my review
Man I just got my SMD DD-1 yesterday !!
and let me tell you this thing is Awesome !!
http://wccaraudio.com/smd-distortion-detector-dd-1.html
you can get them here at the Introductory price still$139(this price will be going up soon ) or check Craig's list there are people that will level your system for you for like 20-25 $ is what I have seen on the Internet
This thing works on factory systems, or aftermarket systems with or with out additional amps in the setup.
By "clip point" I mean at the point of Distortion .
#1 If you are running the factory set up this will work for you to find the clip point of your system
#2 If you are a aftermarket deck and you are just using the deck to power your system doors and rear deck this will work for you 2 to find the clip point.
#3 If you are running a full aftermarket system from 100w RMS to 15,000w RMS you will be able to find your clip point on your deck and amps so your system will be leveled and amp gains will be set like a PRO !!
Now on to my Review
I got it yesterday and read the manual in about 10 min and I was going to wait until this weekend when i could have a friend help but I could not wait to see if it would make a difference with my set up .
so to start you do deck first to find that clip point and then you can do the rest of the system after that .
Now I always thought before I did this that my ear was good and I am a IASCA SQ judge so I thought my clip point was around 38/50 (and it was)well after using the DD-1 and there set up disk exactly how they tell you and tweaking the settings on the deck it is now 45/50 so thats a +#1 right there. Now I know if I turn it up to 46 I will be clipping the deck. (good to know for comps 45 is my magic number )
next you do the full Chanel amp or amps depending on your set up.
Its Super easy to do you just leave you deck on there settings.(flat)
Then you unhook the speaker leads but leave the RCA's in and they tell you what tracks to use on there disk. Turn you gains all the way down.Turn your deck it up to your magic # (45 in my case ) play the track your suppose to (they have Sq and Spl tracks depending what you want your system to do)And slowly turn up the gain until you see the clipping indicator light come on and then you turn it down a little until the light stays off. DONE !! once again you have properly set the amp like a Pro !! Repeat if you have a 4 Chanel or more amps for mids and highs.
And for the sub amp or amps you do the same play the tracks they tell you to depending if you are doing the Sq or Spl and you are Done !!
now just plug everything back in and you system is leveled like a Pro !!
Then you can set your crossover points and tune it by ear or with a RTA and know that your system sounds the best it possibly can . NO CLIPPING or DISTORTION in the system...
On my car I wont know for sure until I hit a TL but I can defiantly feel more pressure. Like I may have gained a couple of DB it is Defiantly better than it was on the Spl setting on the DQXS and my SQ on the DQXS is even more amazing .I was just so you all know running about 3/16 gain on the mids and highs before starting this . now I am running 3/8 on the highs and 1/4 on the mids and I was running 1/8 on the subs and now 5/16 on the subs so all good changes.
BUT like I said I thought I had a good ear for setting up a system UNTIL today LOL
2001 Monte Carlo SS/HS
The Following 4 Users Say Thank You to Blazed SS For This Useful Post:
crucial24 (09-30-2011), djscrubb (09-29-2011), SacTownBully84 (09-30-2011), siccostyle (09-30-2011)
Old 09-29-2011, 04:22 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Thanks for the review. Definitely pushed me over the edge to get mine :-)
The Following User Says Thank You to djscrubb For This Useful Post:
Blazed SS (09-29-2011)
Old 09-29-2011, 04:23 PM
mrtopnotch561's Avatar
0/11 ssssss410
hmm now you got me deciding on whats next.. lol batt or dd-1? decisions decisions
The Following User Says Thank You to mrtopnotch561 For This Useful Post:
0/11 sssss1801
Feedback Score: 17 reviews
can I ask you when you bought it and when you recieved it?
The Following User Says Thank You to jdmferio13 For This Useful Post:
Old 09-29-2011, 04:26 PM
burzendowski's Avatar
0/11 sssss1736
Im getting mine this coming Tuesday. Sounds like you really like the unit. One question i have is ... So you set your gains and clip point with the decks eq flat. Well after you set the gain and clip point, when you adjust your EQ could that cause you to have some distortion or clipping?
Old 09-29-2011, 04:28 PM
Blazed SS's Avatar
0/11 ssssss184
that is easy there are plenty of reviews that are showing with out the clipping that they are using less power so they are more efficient and then you can look at your draw with the system leveled and know better what battery to get for your system
Old 09-29-2011, 04:29 PM
Blazed SS's Avatar
0/11 ssssss184
Man I don't normally do Reviews unless I truly believe in it .This thing is mind blowing good !! And easier than a O scope the old way of doing it . I will be doing my wifes system next she has a aftermarket deck and mid and high 4 channel amp and a sub amp and then it is on to my daughters car Aftermarket deck and a sub amp and probably all my friends cars 2 at no charge !! I just like clean sounding systems !!
Old 09-29-2011, 04:34 PM
Blazed SS's Avatar
0/11 ssssss184
Originally Posted by jdmferio13 View Post
can I ask you when you bought it and when you received it?
Yes you can I ordered mine on 8/9/11 and I was order # 260 he has had some delays with the amount of volume of the orders . So it did take a wile but that was the first day of production .The last thing I read today he is back down to 2 weeks form the date of purchase and is all caught up.
Old 09-29-2011, 04:40 PM
tacomaguy1's Avatar
0/11 sssss4401
I'll pass...teammate has one and it's meh
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
The Following User Says Thank You to tacomaguy1 For This Useful Post:
bad4health (09-30-2011)
Old 09-29-2011, 04:46 PM
0/11 sssss1736
Its meh?? Sounds like a legitimate reason not to buy one.
Wtb smd 18 TnTyuBangin Wanting to Buy (WTB) 3 09-14-2011 08:59 PM
SMD Distortion Detector Testing and Review! twistedchild420 Car Audio Product Reviews 54 07-06-2011 08:09 PM
Aa smd 15" cgriffin224 15" Subwoofers 5 05-14-2011 09:07 PM
SMD alex95sl2 Off Topic Chat 18 03-04-2010 02:30 PM
Another new member from SMD honda New Member Orientation 11 08-11-2008 12:27 PM
