Ctek 7002 charger - Car Audio Classifieds!
Old 12-22-2011, 04:48 PM
0/11 ssssss855
Default Ctek 7002 charger
hello to ALL well this is my review over my ctek charger..
first wanted to start off by saying streetsideauto.com was the cheapest i found this charger any where on the net. For $94 shipped On to the REVIEW
First impressions looked like an over all quality made product, Comes with alligator clamps, Ring terminal connection (all the connections are fused factory with a 15 amp), bag to store it all and well of course the charger.
Normal mode charging 14.4 volts
snow flake 14.7volts
supply to run at 13.6 volts at 7 amps..
recondition 15.7/1.5 amps/0.5amp-4amp
here is some information from the factory..
Fully automatic - for charging and maintenance,
The Universal Charger
A NEW GENERATION of CTEK universal charger, the MULTI US 7002 has a unique 8-step charging curve. This new refined technology developed by CTEK ensures that the vehicle's battery gets the best possible care. It even analyzes if the battery can hold the charge given. If it cannot, the battery is faulty and needs to be replaced. The CTEK chargers are developed for safety: personal, vehicle and battery.
And PICTURES
Starting voltage
Charging
Old 12-23-2011, 12:57 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Looks like a very nice charger! Glad to see someone didn't cheap out were it counts
Old 12-23-2011, 01:34 PM
0/11 ssssss855
thanks lol but in all reality wanted the xs power intelli charger but this will have to do for now charged both my xs power d3100 and my wet cell battery to a full charge yesterday works great
Old 12-27-2011, 03:37 PM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
from my understanding, I was told AGM batts require an AGM dependent charger. I thought these were mainly lead acid chargers.
Speed and SQ
Old 12-27-2011, 04:01 PM
Ja Marcus
0/11 sssss6975
Ctek 7002 - CTEK Multi US 7002 12V Battery Charger |
Says it does them all...
Old 12-27-2011, 04:29 PM
0/11 ssssss855
most chargers have thermal run away (charge at to many volts dc where as in a agm charger its all voltage regulated)
With this charger it is regulated at 14.4 while it is charging at 3 amps it does have different settings for other types of batteries that require a slightly higher charging (14.7)
The down side to using this over a intellicharger is an intellicharger charges at 14.4 volts dc 15 amps max and this charger charges at 3 amps 14.4 which would take more time but still charge them just fine up to 150 amp hour battery
the up side to this charger (ctek 7002) is it has desulphation mode at the start of the charging cycle
Follow up for this review it charges the two batterys i have with no sweat
Old 12-27-2011, 05:26 PM
tacomaguy1's Avatar
0/11 sssss4401
Been in the market for a charger....nice price, gonna have to try it out
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 12-27-2011, 05:37 PM
0/11 ssssss855
Audiofanatics on YouTube and smd recommend it to me and I'd recommend it charges battery pretty quick
Sent from my PG86100 using Tapatalk
Old 12-28-2011, 09:11 PM
0/11 ssssss386
Will this work for a small bank of batteries? Like 4?
Probably not enough amprage?
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 12-28-2011, 09:19 PM
0/11 ssssss855
model on the batterys? how many amp hours?
Tags
xs power d3100 ctek 7002
do i need a battery charger? what battery charger for a D3100? MERQUE General Car Audio Discussion & Questions 18 12-05-2011 10:58 AM
What do you think about this charger? Matt3824 General Car Audio Discussion & Questions 9 08-08-2011 12:26 PM
Battery Charger help super_duper General Car Audio Discussion & Questions 1 09-17-2010 05:40 PM
Charger ? Gary F. General Car Audio Discussion & Questions 2 09-30-2009 09:55 PM
