Audio Technix deadner..... - Car Audio Classifieds!
Old 05-30-2012, 07:39 PM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
Default Audio Technix deadner.....
So I finally ordered some 80mil AT deadener to test out. Shipping was quick and I received a discounted rate. So that was great. Everything started going wrong once the package showed up. The adhesive backing on the foil had gotten smeared all over the inside the box, so I had to literally rip the box apart to get to the deadener. The adhesive had gotten stuck all over the wrong side of the back as well. First thing I noticed was the foil is a extremely rigid. It is close to the same thickness as stinger roadkill expert, but much less flexible. Second, is the plastic film to cover the adhesive is difficult to remove, which leaves more opportunities to be slice by the aluminum backing. Third, the peanut butter colored adhesive is excessively sticky and too "gumy". It has the consistency of chewed up bubble gum. But I figured this would make it stick better.... Wrong...
The area I applied this deadener was the underside of my rear deck. I have previously used stinger roadkill expert and second skin damp pro on this area. Each time, all deadener was removed and the area prepped again. The stinger and second skin where on there about 6 months each. No issues at all.
I got done cleaning all the second skin off, prepped the area using acetone and then a damp cloth. Ensured the area was completely dry, then began the application of the Audio technix. This was an over timely process due to the lack of cooperation from the aluminum backing and the gumy adhesive. I do not use a roller, I use the handle end of a screw driver. It allows me to apply more pressure and get in all the cracks. It takes longer, but is more effective. Ok job done right? WRONG lol. I pop my trunk a few days later and notice the some of the deadener drooping down. So I take the time and reform the deadener. About a week later, I pop the trunk and find a bigger piece of the deadener laying on one of my amps, and the adhesive literally dripping down off the rear deck. I've since ripped all of the crap out. Now I have dripping gumy glue sheet all over my rear deck. I tried some tips from other to remove it with no luck. Its a complete catastrophe. I've asked to send the unused portion back(20ft) a get a refund, but I got a no.
HERE ARE THE PICTURES, KEEP IN MIND, THE DAMP PRO AND ROADKILL EXPERT WHERE APPLIED IN THE EXACT SAME FASHION AND THE EXACT SAME AREAS.
Now if you come in here talkin trash, keep in mind, I've used alot of deadener and adhesive for this crap can't even sustain itself, so there's no way it will hold up and aluminum backing.
Also the over thickness is less than that of damp pro and roadkill expert.
I'd rather pay the premium over priced price of dynamat extreme than deal with this. Damp pro, roadkill expert, and dynamat extreme are superior products.
the two larger pieces had been off less than day in those pics
the smaller pieces were removed at that time, then pictures of the adhesive dripping off the following day.
Team XS Power
Team Heavy Hertz
Build-
youtube-
Old 05-31-2012, 04:13 PM
MasterMod
Guest
0/0 sssssssss
OP has been instructed to contact AT directly regarding his issues.
FS: Audio technix 80mil Boomsday Wiring, Electrical & Other Installation Equipment 5 02-16-2012 03:55 PM
Where is Audio Technix? oslouie General Car Audio Discussion & Questions 4 05-04-2011 05:05 PM
Audio Technix Update old CACO Admin Announcements - Suggestions - Feedback - Support 0 05-03-2011 11:50 PM
Unboxing - Audio Technix, Atmos Audio and Crescendo 5500d Bryan Car Audio Videos 4 04-13-2011 12:15 AM
